Eric67ct Posted June 8, 2020 Share Posted June 8, 2020 I have a '06 OBXT 5eat and I am installing the LGT caliper/rotor/pad/SS line upgrade. I am using: -Stoptech blank rotors -NAPA Eclipse calipers -Akebono Ceramic pads -Stoptech SS brake lines When putting the pads onto the calipers with the clips installed, it seems like there are (2) wear clips on the Akebono pads (pics included). Clip 1 interferes with the caliper clip that goes inside the caliper. Do you recommend cutting off this clip to fit? Will clip 2 provide wear indication as well? Thanks, Eric Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2020 Share Posted June 9, 2020 (edited) I believe that thin one is a return spring type feature, it pushes against the outer surface on the caliper bracket. Edited June 9, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
