jaylew Posted May 22, 2020 Share Posted May 22, 2020 Calling anyone that has a 2005 GT Limited with Manual Transmission. A while back I lost the cover to my engine bay fuse box. I replaced it with a junk yard unit (does the job) but the sticker layout is wrong. Could anyone with the right engine bay fuse box cover just send me or post in reply a picture of the layout sticker on the cover of the fuse box? Thank you very much!!!! Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2020 Share Posted May 22, 2020 (edited) https://www.google.com/search?q=2005+Legacy+GT+fuse+box+lay+out&oq=2005+Legacy+GT+fuse+box+lay+out&aqs=chrome..69i57j0.11119j0j8&sourceid=chrome&ie=UTF-8 does anything there help ? MAY BE NOT... Edited May 22, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubOperator Posted May 22, 2020 Share Posted May 22, 2020 https://fuse-box.info/subaru/subaru-legacy-2005-2009-fuses 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2020 Share Posted May 22, 2020 I did take photos of both my cars covers and boxes. Sorry I don't have a Limited. But might be helpful for some one else. 2005 non-limited GT 2009 Spec B 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted May 22, 2020 Share Posted May 22, 2020 Max, that first one is the same exact cover on my '05 LGT MT; it should be just what he needs. I have a spare cover if the OP wants one that matches again Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2020 Share Posted May 22, 2020 If you look at the main fuse box in both my pictures, they are pretty much the same. Its that small box on the angle where thing are different. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jaylew Posted May 22, 2020 Author Share Posted May 22, 2020 (edited) Thank you Max for the pictures! SubOperator thanks for the link, I'll save that for the future. I was more interested in the relay's but was keeping it generic at first. I've been getting an intermittent P0691 accompanied by the stereo not powering on. I turn off the car immediately. Any google searches bring me to the fan relay recall. My primary fan relay looks like yours Max, but I have a different Sub Fan relay(mine is the standard blue looking one). I might just replace both to be safe and see what that does. I really don't want to brick my ECU from some circuit short. And Infosecdad, thank you for the offer! I think I'll just work off the images for now Edited May 22, 2020 by jaylew Wagon is LIFE! - 265,000 miles and climbing Unofficial Build (Restoration) Thread Steering Rack Rebuild Link to comment Share on other sites More sharing options...
Max Capacity Posted May 23, 2020 Share Posted May 23, 2020 FWIW, a couple years back I replaced both AC relay's with new OEM from the dealership. They were like $7.00 each. Both cars continue to blow cold air when the AC has been on for a long time. So hopefully other's are that cheap. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
