Max626 Posted May 19, 2020 Share Posted May 19, 2020 Before I purchase and new “use” harness for my 98 legacy I figured I’d try one last time to find out what the problem is. Car was fine before I put my coil overs on, took car off jack the stands it wouldn’t start. When I remove the key I still have a 6-7volts at the ignition (Black wire & Black/Blue). I bench tested everything even swapped ECUs, relays and still same issue. I’m down to it being a faulty wire somewhere in the harness that I can’t pinpoint. Any input will be helpful Link to comment Share on other sites More sharing options...
