need bb Posted May 3, 2020 Share Posted May 3, 2020 I am trying to run a wire from the driver side fuse box to the ECU on the passenger side so I can monitor my wideband sensor via the ECU's TGV input. My wideband connections all terminate by the driver's side fuse box and I am struggling on finding a way to easily run this wire across the dash. When I poked around with a coat hanger by the footwells there didn't seem to be any passage way. Would it just be easier to run the wire around the shifter/cigarette lighter? Any suggestions would be appreciated. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted May 3, 2020 Share Posted May 3, 2020 If you pull the cover around the shift lever you can get your hand in there and feed through that, it's not bad just tedious 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
DaveWaters Posted May 3, 2020 Share Posted May 3, 2020 Theres a way through. It’s tough to find. I use a 3’ or so hvac zip tie with the end cut off to find the way. Then I tape the wire to it and pull it through. More flexible than a wire hanger but same idea. I’ll see if I can get a picture of both sides tomorrow so you’ll have an idea where to get across. I’ve pulled several wires including 4g amplifier power. Link to comment Share on other sites More sharing options...
need bb Posted May 3, 2020 Author Share Posted May 3, 2020 Theres a way through. It’s tough to find. I use a 3’ or so hvac zip tie with the end cut off to find the way. Then I tape the wire to it and pull it through. More flexible than a wire hanger but same idea. I’ll see if I can get a picture of both sides tomorrow so you’ll have an idea where to get across. I’ve pulled several wires including 4g amplifier power. That would be greatly appreciated. Link to comment Share on other sites More sharing options...
DaveWaters Posted May 3, 2020 Share Posted May 3, 2020 Driver’s side (disregard the smaller red wire) Passenger’s side Hope this helps Link to comment Share on other sites More sharing options...
need bb Posted May 3, 2020 Author Share Posted May 3, 2020 Thanks! Looks like a straight path through? Link to comment Share on other sites More sharing options...
need bb Posted May 4, 2020 Author Share Posted May 4, 2020 Driver’s side (disregard the smaller red wire) Passenger’s side Hope this helps Thanks, I was successfully able to find this passage way:spin: Link to comment Share on other sites More sharing options...
DaveWaters Posted May 4, 2020 Share Posted May 4, 2020 Awesome! Glad it worked out for you. Link to comment Share on other sites More sharing options...
