YeuEmMaiMai Posted April 30, 2020 Share Posted April 30, 2020 (edited) If you ever have to replace them, Subaru states to take the intake off....yeah, no. here is how you do it 1. Disconnect battery 2. Remove Engine cover (if you still have it) 3. Remove Serpentine belt, marking what side faces front of car. 4. Remove idler pully under alternator (easier access to loosen the long bolt on bottom of alternator. 5. Remove positive alternator termial, control plug, A/C sensor pressure plug. and gray plug to right of A/C pump. 6. unclip harness from black channel that is part of the engine cover bracket 7. remove engine cover bracket 8. loosen lower alternator bolt 9. remove top left alternator bolt that you loosened to remove engine cover bracket 10. remove alternator 11. Remove barometric sensor on left side of intake 12. using a 10 or 12 mm (I forgot) socket, universal joint, and 9" extension, loosen passenger side knock sensor and then rotate it a bit so you can easily unplug it, t 14. on the driver side go in to the left of the A/C compressor and use a long screw drover to press in the clip and then tap the screw driver so the connector moves back a bit so that the lock does not re-engage 15. Go in behind the A/C compressor and remove the knock sensor bolt completely then pull the sensor up and unplug it. to install the driver side knock sensor 16. while holding connector with one hand use a set of needle nose plyers to insert the knock sensor into the connector until it clicks. 17. insert bolt into knock sensor ***this part is the pitb if you have large hands due to limited space*** 18. get the nock sensor back over the hole and use your fingers to start the bolt.. you will know if you have it when you cannot lift up on said bolt 19. while holding the knock sensor in the correct position, tighten bolt to install the passenger side sensor 19. put bolt into sensor 20. reach in and start the bolt 21. rotate sensor so you can plug connector in 22. while holding sensor in correct position, tighten bolt the passenger side is much easier due to lack of hard lines under intake 23. reinstall barometric sensor 24. reinstall alternator 25. reinstall front idler pully 26. reinstall serpentine belt noting what side goes towards the front of the car. 27. reinstall alternator power lead, connector, a/c pressure switch, and gray connector and clip harness back to front cover 28. reconnect battery. 29. reinstall front engine cover Start car and verify all is working as it should Edited May 1, 2020 by YeuEmMaiMai Link to comment Share on other sites More sharing options...
dgoodhue Posted April 30, 2020 Share Posted April 30, 2020 How are you going to torque the knock sensor to spec? I am not positive about Subaru knock sensor, but many knock sensors calibration is affect by the torque. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 30, 2020 Author Share Posted April 30, 2020 you can use a torque wrench Link to comment Share on other sites More sharing options...
dgoodhue Posted May 1, 2020 Share Posted May 1, 2020 you can use a torque wrench Not with a swivel. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 1, 2020 Author Share Posted May 1, 2020 Not with a swivel. well unless you want to take an intake manifold off, that is your only other route... personally I just snugged them down and 1/4 turn more which was about what they were tightened to...I am aware that a swivel will affect torque based upon angle... but since the angle is small you can add 10% or so and be done with it spec is 14ftl lbs so barely tight the code has not returned, it typically showed up in the first 10-14 mins of driving so I think we are good to go here... Link to comment Share on other sites More sharing options...
