Chocoholic005 Posted April 17, 2020 Share Posted April 17, 2020 (edited) *Prices do not include shipping unless specified. Message me and I'll get you a quote. - EJ257 out of an 05 Legacy GT. Single AVCS w/ B25 heads, stock. 203k miles with low compression on cylinder 4 (80 psi) and failed leakdown. Ran when removed. Good candidate for a rebuild, includes everything you see pictured. Prefer not to ship, but we can talk. (SOLD) - Engine rebuild gasket, seal and hardline assortment. This is spare stuff I ordered that I either didn't need or couldn't end up using. Purchased everything for the 05 EJ257 w/ B25 heads, but 90% will fit any EJ25 turbo. Everything is brand new and totaled ~$350 before taxes/shipping. Sold some parts of this kit; inquire about individual items. Valve Cover Gasket Right – 13270AA190 (SOLD) Valve Cover Gasket Left – 13272AA140 (SOLD) Woodruf Key – 804505060 (SOLD) Coolant Crossover Pipe O-Rings (x2) – 806933010 (SOLD) Water Pump Gasket – 21114AA051 (SOLD) Water Pump Side Seal – 21116AA010 (SOLD) Intake Manifold to TGV Gaskets (x4) – 14035AA492 (SOLD) Rear Cylinder Head Half Moons (x4) – 11051AA070 (SOLD) Turbo Oil Feed Line – 15192AA490 (SOLD) Passenger AVCS/Turbo Oil Feed Line - 15192AA432 Turbo Oil Drain Hose - 807515712 (SOLD) Water Stay Pipe Bracket - 14058AA000 6 Speed Flywheel Pilot Bearing – Clutch Masters Part (SOLD) Throttle Body to Intake Manifold Gasket - 16175AA331 (SOLD) B25 AVCS Camshaft Seals (x2) – 806742160 (SOLD) B25 non-AVCS Camshaft Seals (x2) – 806732160 (SOLD) Oil Pump to Crankshaft Seal - 806733030 (SOLD) Wrist Pin Clips - 805323040 (SOLD) Keepers - 13210AA020 (SOLD) Exhaust Manifold Gaskets (x2) – 14038AA000 (SOLD) Valve Seals - 13207AA120 & 13211AA110 (SOLD) TGV to Intake Manifold Gaskets (Paper) – IAG (SOLD) TGV to Cylinder Head Bolts/Washers – IAG Downpipe Hanger Bracket – 44021AG00A Deatschwerks Side Feed Injector O-ring Kit – 2-002-4 - VF40 - used. Unknown mileage, fins look pretty decent, there's some minor shaft play, but no housing contact. Could be used again, but probably a rebuild candidate long term. (SOLD) - 6 Speed Reverse Lockout Pull. Good shape, see pictures. $25.00 shipped to the US. - Legacy GT 5 Speed Driveshaft. Used, out of an 05 wagon. No issues. $50.00. - 5 Speed Clutch/Flywheel/Pressure Plate. Used, but with 50% life left or more. $50.00. - Brembo Front Helicoil Kit w/ 4 Inserts. SOLD - 2005 Legacy GT Booster & Master. Used, but functions fine. $30.00. - Homemade bulletproof TMIC (resin), no leaks. $30.00. - Facelift 08-09 Legacy Grill. Used in good condition. $50.00. Edited June 19, 2020 by Chocoholic005 Link to comment Share on other sites More sharing options...
Chocoholic005 Posted April 17, 2020 Author Share Posted April 17, 2020 More photos. Link to comment Share on other sites More sharing options...
Chocoholic005 Posted April 27, 2020 Author Share Posted April 27, 2020 Sold some stuff update. Link to comment Share on other sites More sharing options...
Chocoholic005 Posted May 2, 2020 Author Share Posted May 2, 2020 Motor Sold. Link to comment Share on other sites More sharing options...
