Surfcast23 Posted April 6, 2020 Share Posted April 6, 2020 I just replaced my starter and when I went to start it (by jumping) the starter clicked rapidly and the car would not start. I also got the Er 1u error in the odometer which I read means that there is an error in the Body Integrated Unit or a very dead battery. My question is since I am jump starting shouldn't it start after a while of being connected to the other car? I am also concerned by the rapid clicking. any ideas? Link to comment Share on other sites More sharing options...
whitexc Posted April 7, 2020 Share Posted April 7, 2020 Sounds like the battery isn't up to the task. Sent from my moto z3 using Tapatalk Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 7, 2020 Share Posted April 7, 2020 Sounds like the battery isn't up to the task. Sent from my moto z3 using Tapatalk ^^ This Multiple clicks is the battery Single click/clunk is the starter Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2020 Share Posted April 7, 2020 Did you clean the battery terminals ? are they tight ? How old is the battery ? Some will last 7 years. Others not so much. I normally replace mine before its 6th Winter. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 7, 2020 Author Share Posted April 7, 2020 Sounds like the battery isn't up to the task. Sent from my moto z3 using Tapatalk Shouldn't I still be able to start it by jumping it? Did you clean the battery terminals ? are they tight ? How old is the battery ? Some will last 7 years. Others not so much. I normally replace mine before its 6th Winter. Terminals are tight and I will give them a more thorough cleaning today. I am not sure about the age of the battery. I have had the car for five years, but do not know if or when it may have been changed by the previous owner. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2020 Share Posted April 7, 2020 In theory you should be to disconnect the battery cables and hook them directly to the jumper cables and see if you can start the car. Dose that sound right ? I know I have connected jumper cables to the winch power connector on the trailer and used the winch. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 7, 2020 Author Share Posted April 7, 2020 In theory you should be to disconnect the battery cables and hook them directly to the jumper cables and see if you can start the car. Dose that sound right ? I know I have connected jumper cables to the winch power connector on the trailer and used the winch. I tried that resulting in the same rapid clicking. I am hoping that the issue is bad corrosion in the positive battery cable where it connects to the clamp. I have the nut soaking now. I'll report back after I look at it. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted April 7, 2020 Share Posted April 7, 2020 Check your engine grounds from the heads to the frame, if they are rotted off not enough current will be able to flow. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 7, 2020 Author Share Posted April 7, 2020 Took the clamps off and the wire a very small amount of corrosion so I don't think that's the issue/ Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 7, 2020 Author Share Posted April 7, 2020 Check your engine grounds from the heads to the frame, if they are rotted off not enough current will be able to flow. Where are the grounds located? Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted April 7, 2020 Share Posted April 7, 2020 Where are the grounds located? bottom side of each head, oem wires are braided and corrode easily, if they aren't there that's a problem 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2020 Share Posted April 7, 2020 There's the ground wires I made for my Spec B. Under the engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted April 7, 2020 Share Posted April 7, 2020 Here's my wagon's, 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 7, 2020 Author Share Posted April 7, 2020 Would it be safe to bypass the cables and connect my working battery directly to the starter? Link to comment Share on other sites More sharing options...
DaveWaters Posted April 8, 2020 Share Posted April 8, 2020 If you have a known working battery from another car just remove it from the other car and connect it to the terminals in place of the current battery temporarily to see if it starts. If it does then you’ll know you need a new one for sure. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 8, 2020 Author Share Posted April 8, 2020 If you have a known working battery from another car just remove it from the other car and connect it to the terminals in place of the current battery temporarily to see if it starts. If it does then you’ll know you need a new one for sure. I tried that and the result was the same rapid clicking. Link to comment Share on other sites More sharing options...
DaveWaters Posted April 8, 2020 Share Posted April 8, 2020 How about this ground? Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 8, 2020 Author Share Posted April 8, 2020 How about this ground? Is that above the starter? I can't really tell form the picture where it is in the engine bay. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 8, 2020 Author Share Posted April 8, 2020 If that's the one connected to the starter I took the bracket off with out removing it. I'll check tomorrow to make sure that it didn't get jostled. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 8, 2020 Share Posted April 8, 2020 Is the trigger wire on the starter tight? If you have a test light, have someone attempt to start the car while probing the trigger wire. You should have 12v all the time on the main power wire at the starter and power on the trigger wire while cranking. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 8, 2020 Author Share Posted April 8, 2020 Is the trigger wire on the starter tight? If you have a test light, have someone attempt to start the car while probing the trigger wire. You should have 12v all the time on the main power wire at the starter and power on the trigger wire while cranking. Is the trigger wire the small wire at the back of the starter underneath the power line? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 8, 2020 Share Posted April 8, 2020 If it's not below, its next to it. Its hooked to the Male spade on the starter. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 8, 2020 Author Share Posted April 8, 2020 If it's not below, its next to it. Its hooked to the Male spade on the starter. I did reconnect that when I was instating the starter. I'm going to take it all apart to see if I missed anything once it stops raining. Link to comment Share on other sites More sharing options...
Surfcast23 Posted April 25, 2020 Author Share Posted April 25, 2020 I finally had a chance to work on it again today. I connected a battery pack directly to the starter and it started right up. I then tried to jump it and again got the rapid clicking with no start. I am think that the issue maybe the cable to the starter, any thoughts? Link to comment Share on other sites More sharing options...
08SpecB_DE Posted April 26, 2020 Share Posted April 26, 2020 (edited) Sounds like you're on the right track. It wouldn't be hard to make your own and give it a try. Have you tried checking the power wire at the starter with a test light? It should be very bright. If the ground is not clean, that can cause a similar problem. May be a dumb question, but did you connect the power wire to the correct terminal on the starter? Edited April 26, 2020 by 08SpecB_DE Link to comment Share on other sites More sharing options...
