06SubLegTx Posted April 5, 2020 Share Posted April 5, 2020 Hello, Car Info: 2006 Legacy 2.5i Limited Sedan. 163k Blowing the "Tail Clearance Fuse" in the driver side lower fuse panel. The 15 AMP blows every time I use the Combination Switch or Hazard Rocker switch on top of the steering column. (These two Parts are linked to the "Tail Relay" in the main fuse box). I have check the rear Tail lights, no shorts in the wiring there. No shorts in the Licence Plate Lights either. I then disconnected those from the rear wiring harness from the wires, and it still blows the "Tail Clearance Fuse". Do the Combination Switch or Hazard Rocker have a history of being/going bad? Link to comment Share on other sites More sharing options...
