proflashrtist Posted January 5, 2014 Share Posted January 5, 2014 Well there is 1 ways to go about this. Make it your primary system(stock radio still there just not used) or get a harness and wire up both the DVD and OEM headunit so you can use either or. Another possiblity to look into if you are going the route of replacing your OEM NAVI is the JDM dual din mod. It might be a cheaper route. Plus this you can use the OEM NAVI still and just end up replacing you OEM Headunit with an in dash Navi unit. This way you don't loose your goodies from the OEM NAVI. So..in a turn of events today..BOTH best buy and Custom Sounds told me today they cannot install any after market radio into my car. Period. Apparently there's no harness or install kit. Custom sounds even took apart my entire dash ..took the Nav and radio out to look and said there's just no way because they would have to rewire to the stock amp and blah blah blah...lame. Snookie I have a car that has a crapy out of date Nav system and no option to replace. Link to comment Share on other sites More sharing options...
evil03mustang Posted January 6, 2014 Share Posted January 6, 2014 So..in a turn of events today..BOTH best buy and Custom Sounds told me today they cannot install any after market radio into my car. Period. Apparently there's no harness or install kit. Custom sounds even took apart my entire dash ..took the Nav and radio out to look and said there's just no way because they would have to rewire to the stock amp and blah blah blah...lame. Snookie I have a car that has a crapy out of date Nav system and no option to replace. I'll bet Steve Meade can do it. Link to comment Share on other sites More sharing options...
zisforzachary Posted August 3, 2014 Share Posted August 3, 2014 bump. has anyone done this yet? i feel like there was a thread out there but i cant find it now Link to comment Share on other sites More sharing options...
AkumaMax Posted August 4, 2014 Share Posted August 4, 2014 yes I put an OEM navi into my 05. A lot of work and time to build the harness. If you look into my profile and look for threads create it should be in there. Link to comment Share on other sites More sharing options...
