Tsunamijedi Posted November 27, 2019 Share Posted November 27, 2019 i have a 2005 legacy gt and im looking to replace the aging turbo. Has anyone used the Mahle oem spec vf40? im guessing since its an oem spec turbo i wouldnt have to get retuned correct? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 27, 2019 Share Posted November 27, 2019 for others that are wondering, https://www.bing.com/search?q=Mahle+oem+spec+vf40&src=IE-SearchBox&FORM=IENTSR Rallysport has been around for a while, so they should be a good place to buy from. Most of us use member JmP6889928 as the "go to guy" to rebuild are turbos. Also my Tuner tuningalliance@gmail.com will rebuild them too. Not sure if your car is still on the OEM Map but most of us have learned that a Tuned car runs a lot better for a longer time. You have come to the right place to ask. Read some of the threads, you'll learn a lot. Not sure where you live, but when I needed a new turbo, I called www.AZPinstalls.com about 9AM, I had the new vf52 the next day. Met the Tuner at the Dyno the next day, that vf52 has over 140,000 miles now. The vf52, with Cobb AP V3 and a custom tune, you'll be amazed at how great the car runs. You should remove the OEM catted up pipe and replace it with a "take off" from a STI or buy one of the after market non-catted up pipes like some of us do. A 3" catted down pipe will mate to your stock exhaust and your car will be no louder then it is now, but will get better mpg and have more AWHP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ttnio Posted November 27, 2019 Share Posted November 27, 2019 VF-40 oem part. plug and play. Link to comment Share on other sites More sharing options...
