wayne1998 Posted October 8, 2019 Share Posted October 8, 2019 I have a 98 Legacy GT sedan and I need to remove interior A and B pillar trim. Anyone know of a video or where I can find the procedure in written form. I have alldata and it does show it. Thanks Link to comment Share on other sites More sharing options...
Brighton96 Posted October 8, 2019 Share Posted October 8, 2019 I don't know of any videos that exist but they are easy to remove. The A's are just held in with clips. Just carefully pry with your fingers starting from the top and pop the clips free (there are 3 or 4) and then it's sort of wedged between the dash and body so it'll require a little wiggling. The B's will require a socket to remove the seat belt mount but other than that you shouldn't need any tools. For the B's you may need to slightly dislodge the lower portion of the B's since they overlap the upper portion, but same procedure, just carefully pry away with your fingers and there are only 4 or 5 pins holding it in. BTW this is entirely from memory and it's been a while since I have done it haha. Link to comment Share on other sites More sharing options...
