4S3BP67676 Posted August 24, 2019 Share Posted August 24, 2019 So last weekend I impulse bought a 2007 Legacy GT sedan A/T The previous owner sold it to me cheap because he got half way through a turbo swap and gave up. Well I got everything under the hood settled, but when I went to start the car, there’s no response at the starter. - I noticed there’s a problem with the stereo, bad connection or something that makes it flicker on and off, - there’s a “CrimeStopper” aftermarket keyless entry and remote start in it. The battery in the remote of dead. - everything besides the remote start appears to be stock - the OBD2 port loses power in the key-on position so I can’t scan the car. - the battery was dead when I bought it, so there won’t be any code history - the “” icon is flashing in the cluster - the starter relay clicks, and there is power at 30 and (85 or 86) (Now that I think of it, the starter relay might be normally closed? Is that normal?) - I bench tested the starter, verified power at the starter positive cable, and turned the engine over by hand so I’m pretty sure everything is good under the hood So as my first step I disabled the stereo and started uninstalling the remote start I’m not sure what my next steps should be. I’ll probably try to trace the starter circuit. Anyone have any idea what the issue could be? Or what I should check? If I can swap a part out for something off my ‘06 M/T wagon to get my sedan running, that is an option I have. (Never posted to this site before, but figured I’d give it a try considering this issue is a little out of my comfort zone.) Link to comment Share on other sites More sharing options...
ehsnils Posted August 24, 2019 Share Posted August 24, 2019 It seems like you at least have some knowledge about electrics, so I think that you should start over here: https://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2019 Share Posted August 24, 2019 Here this is easier, the service manual, http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
4S3BP67676 Posted August 24, 2019 Author Share Posted August 24, 2019 Wow thank you very much, that will definitely come in handy! I made a mistake in the original posting. The relay I checked thinking it was for the starter was the wrong one. The starter relay is not activating. On the coil side it shows a voltage (I don’t remember the exact readings, but it showed either a 5V ref or 12V) I bypassed the relay (switch side) to test the starting circuit and everything seemed to turn over fine. So I guess it’s down to something causing the ECU to prevent the engine from starting. I’m guessing it’s gotta be something with the immobilizer, but it’s gonna be difficult to find out for sure without OBD2. I won’t have the resources I need to diagnose/repair the OBD2 problem until Monday. Is there any way to test the integrity of the ECU with the vehicle in this state? Link to comment Share on other sites More sharing options...
blue wrench Posted August 25, 2019 Share Posted August 25, 2019 I think you have the right idea by removing the aftermarket remote starter to begin with, just to rule that out all together. As far as getting no response from the starter, look into the 'security relay' and its circuit. This was a while ago so I don't remember it exactly, but I believe the security relay is what controls the starter relay circuit, and is signaled by the ECM. With the vehicle I found this on, it was a matter of narrowing it down to the ECM itself, after finding no problems with the security relay itself and its circuit. Used ECM fixed it. Link to comment Share on other sites More sharing options...
ehsnils Posted August 25, 2019 Share Posted August 25, 2019 The security relay is involving two things, neutral position sensor and clutch sensor for manual gearbox vehicles. If the engine starts and keep running when the relay is bypassed it's not the immobilizer since that usually results in the engine starting and then turning off after 10 seconds. Link to comment Share on other sites More sharing options...
4S3BP67676 Posted August 28, 2019 Author Share Posted August 28, 2019 Ok, thanks everyone for the help. So I think I’ve got it mostly figured out. It was not a problem with any of the computers, but a bad ground connection. When I tested my DLC for ground with my bolt meter, I found the same strange readings I got on the starter relay. 0.5V key off or in accessory and 10V key on. So I ran an auxiliary ground directly to the starter relay ground and that solved my starter issue, but I still wasn’t getting fuel until I grounded the ground wire on the back of the DLC with a separate auxiliary ground. Now the only issue I have left is I have no communication at the transmission unless I have something plugged into the DLC when the car is started. Plugging or unplugging after the car is started seemed to have no effect. But as far as I’m concerned, the car is driveable now. Thanks Link to comment Share on other sites More sharing options...
