Pleides Posted August 8, 2019 Author Share Posted August 8, 2019 Also worth to double-check the cam timing for 2 and 4 so you don't waste time on the wrong problem. Slightly off timing could lead to compression error. I assume this would have been obvious with a timing belt job? Ben replaced the timing components about 1K miles ago since I had a cam seal leak. Link to comment Share on other sites More sharing options...
ehsnils Posted August 9, 2019 Share Posted August 9, 2019 I assume this would have been obvious with a timing belt job? Ben replaced the timing components about 1K miles ago since I had a cam seal leak. Not necessarily, one cog off on the cam could theoretically be an issue - it don't hurt to check that the cam job was done right. Especially on a separate exhaust/intake cam engine it's darn hard to miss one tooth off on a single cam - I know that from own experience. Link to comment Share on other sites More sharing options...
Pleides Posted August 9, 2019 Author Share Posted August 9, 2019 Not necessarily, one cog off on the cam could theoretically be an issue - it don't hurt to check that the cam job was done right. Especially on a separate exhaust/intake cam engine it's darn hard to miss one tooth off on a single cam - I know that from own experience. I would assume this is a hardware-level problem, not something that could be noted electronically either, correct? Do I just remove the timing cover or what all needs to be removed? Link to comment Share on other sites More sharing options...
gkinslow Posted August 9, 2019 Share Posted August 9, 2019 Correct, visual inspection. You'll have to remove the accessories belt and crank pulley to get 2/3 of the timing cover off, but I believe thats it. Link to comment Share on other sites More sharing options...
