Falcor Posted July 6, 2019 Posted July 6, 2019 Before I start tearing into it, has this happened to anyone else? When the parking brake button is pushed, right at the end of the cycle, there is a squeak. My first thought was the eventual recall of the parking brake and my is finally starting to act up, but then I started wondering if something at the rear wheels needs lubed. Any ideas?
Alexmed2002 Posted July 6, 2019 Posted July 6, 2019 Before I start tearing into it, has this happened to anyone else? When the parking brake button is pushed, right at the end of the cycle, there is a squeak. My first thought was the eventual recall of the parking brake and my is finally starting to act up, but then I started wondering if something at the rear wheels needs lubed. Any ideas? I found this forum and I think it might help... : https://legacygt.com/forums/showthread.php/2011-rear-pads-rotor-change-226465.html
Falcor Posted July 7, 2019 Author Posted July 7, 2019 Thanks for the link. I'll probably pop the rotors off and check everything out and see what's going on.
Alexmed2002 Posted July 7, 2019 Posted July 7, 2019 Thanks for the link. I'll probably pop the rotors off and check everything out and see what's going on. Ya from the sounds of the forum I linked, that would be your best bet.
DrD123 Posted July 7, 2019 Posted July 7, 2019 hopefully it's just something that needs lubricated (I haven't done drum brakes in quite some time, but the contact points where the shoes touch the backing plate are a good place to check/lubricate) For the recall, I think that's en electrical issue, so shouldn't make noise, I don't think - sort of disheartening that the recall has been open for so long, but there is still no remedy available!
ICE7 Posted July 12, 2019 Posted July 12, 2019 I found this forum and I think it might help... : https://legacygt.com/forums/showthread.php/2011-rear-pads-rotor-change-226465.html Yup...from me I am experiencing this same issue....I'll have to look into this situation also.
