Pearlyy Posted July 3, 2019 Share Posted July 3, 2019 Got this legacy about 2 months ago, for a month i had the abs light coming on intermittently but now it’s on 24/7. It displays “ER 55/SS” on the odometer. Can also hear a slight squeak when inching forward, any idea of what it could be? Wheel bearing or speed sensor? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 3, 2019 Share Posted July 3, 2019 Check the Speed sensor wire and/or probe into the wheel hub assembly. If the sensor was working but outside what the ECU likes, you would get a meaningful code such as P0501/2/3/4/0. That code indicates that the CAN isn't responsive. Link to comment Share on other sites More sharing options...
NORULZleggy Posted July 3, 2019 Share Posted July 3, 2019 Replace the sensor, I had an issues like this and my outback was acting crazy. I hit up rockauto and installed the new one and it went away. they are 22-30 bucks shipped. Link to comment Share on other sites More sharing options...
JmP6889928 Posted July 3, 2019 Share Posted July 3, 2019 Most likely speed sensor. I have a set of both fronts that were working fine when removed you can have for $50.00 shipped if you want them. PM me. Link to comment Share on other sites More sharing options...
gimpydingo Posted July 3, 2019 Share Posted July 3, 2019 After I had my tired rotated the ABS light came on about a mile after driving the car. There was also a slight squeak when I turned the car. Took calipers apart, cleaned everything, put it back, and all was good. Link to comment Share on other sites More sharing options...
