Ilubeyousubaru Posted June 11, 2019 Share Posted June 11, 2019 (edited) I recently put a hitch on my 2008 2.5 Legacy 5 spd and was wondering what are my options to raise the back so I get more clearance when towing my jetski and stop getting weird looks. Total weight of towing is around 1100 lbs and tongue weight is about 120 lbs. My friend suggest air shocks, I don't think that would work with coil overs. I have stock rear suspension that are already sagging and was wondering if spacers would get me by. Can someone recommend me some spacers? The driver's side rear sags a bit more. Edited June 11, 2019 by Ilubeyousubaru last sentence added Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted June 11, 2019 I Donated Too Share Posted June 11, 2019 https://www.paranoidfabrications.com/collections/subaru-legacy/products/00-15-rear-subaru-legacy-lift-spacers Link to comment Share on other sites More sharing options...
nevets27 Posted June 12, 2019 Share Posted June 12, 2019 Wagon springs in the rear might be an idea. Not sure if they will fit on the stock sedan shock. As I thought I read they are a bit taller/longer. I'm sure someone here knows. Link to comment Share on other sites More sharing options...
Ilubeyousubaru Posted June 13, 2019 Author Share Posted June 13, 2019 Does anyone have the template to the rear spacers? Link to comment Share on other sites More sharing options...
Dkraim Posted June 14, 2019 Share Posted June 14, 2019 I'm having the same problem! But idk if I get quick struts or look for a stiffer suspension for I will be towing?.. I'm looking for some brands or websites Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Ilubeyousubaru Posted June 14, 2019 Author Share Posted June 14, 2019 All the options I could find pointed me to do this as a DIY. I ended ordering a sheet of HDPE 3/4"x12"x12" sheet from McMaster for $21. I'm going double up on the layer and fabricate it where the one layer that will sit on the top hat will have the hole in the middle and another layer on top of that without a hole in the middle. I will try to remember to take pictures for future reference. Link to comment Share on other sites More sharing options...
Ilubeyousubaru Posted June 20, 2019 Author Share Posted June 20, 2019 So I ended not having to double up on the 3/4". I got the stenciling done and jigsawed the pieces, done by 11 pm. Took about a total of 4 hours. I will take pictures of the stencil for whatever it's worth. If you are going to make your own stencil. I recommend using cardboard that is atleast 2-3 layers thick. I say this because on the top hat, the center rubber grommet flairs inward into the base that makes it hard to center and stencil. I eyeballed everything. Also over size all holes a bit. It's an easy job with a decent impact wrench and a helper. Link to comment Share on other sites More sharing options...
