subiesin1 Posted May 16, 2019 Share Posted May 16, 2019 I’m currently at stage 1 on my 05 lgt, I’m looking to go to stage 2. Is it possible to go to stage 2 with a 2014 wrx downpipe? Link to comment Share on other sites More sharing options...
whitetiger Posted May 16, 2019 Share Posted May 16, 2019 an OEM wrx DP or an aftermarket one? If OEM with the stock cats, no. If aftermarket catless or high flow cat, then yes as long as it fits. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 16, 2019 Share Posted May 16, 2019 (edited) Make sure it will fit your car. Go to Invidia's web site and see what the prat number is for both cars If the DP is the same part number then it will fit. Oh here, it fits. https://www.importimageracing.com/products/invidia-catless-divorced-downpipe-subaru-wrx-2008-2014-sti-2008-2019-legacy-gt-mt-2005-2009 Make sure you cut back the divider plate. I happen to have a catless on for a 5mt in my basement. Took it off last Fall to put on a catted one. Edited May 16, 2019 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
