JLJ05LGT Posted May 12, 2019 Share Posted May 12, 2019 (edited) So im having a full Rebuild done on my 05 lgt. Long story short, the avcs solenoid was stuck to head and ended up getting broke. Other head is fine. I have another cylinder head, my question is can i mismatch the heads(seperate the set) if they're getting decked and it be okay? Ive heard not to seperate the heads but this build has sucked me dry on funds and im not wanting to purchase a whole new set of heads. All help is appreciated! UPDATE: went ahead and with a different set of heads. Wasnt worth the worry. Sent from my SM-G950U using Tapatalk Edited May 12, 2019 by JLJ05LGT Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2019 Share Posted May 13, 2019 Yes, the machine shop will recondition the heads and you'll be fine. Ask the Shop, they will tell you... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
