Mluetch Posted May 8, 2019 Share Posted May 8, 2019 We just got a 2005 LGT, automatic, white with black interior, leather, heated seats, sunroof and 153,000 miles. The car is an 8 on a scale to 10. It has the following mods: 2011 WRX wheels Cobb AP Perrin top mount TGV delete STi tope feed injectors Invidia catless dp and q300 exhaust Mishimoto radiator, hoses, expansion tank, overflow tank K&N typoon intake Tein S-tech lowering springs Cusco front and rear lower sway bars S/S front brake lines Advanced caster front LCA bushings Double din head unit conversion What's this worth? Link to comment Share on other sites More sharing options...
whitetiger Posted May 8, 2019 Share Posted May 8, 2019 $4kish. was a compression/leak down test done? does the car have a blown turbo in its history? is the trans shifting well? the car normally comes with side feed injectors for that year, and the mods on it don't usually require a top feed conversion. is the engine still original to the car? Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 8, 2019 Share Posted May 8, 2019 $4kish. Is that on account of the 5EAT? Granted I've only ever looked at 5MTs, but cars in this range with similar mods seem to come up in the $6-$8k range in my experience. Link to comment Share on other sites More sharing options...
Mluetch Posted May 10, 2019 Author Share Posted May 10, 2019 Thanks Link to comment Share on other sites More sharing options...
whitetiger Posted May 10, 2019 Share Posted May 10, 2019 Is that on account of the 5EAT? Granted I've only ever looked at 5MTs, but cars in this range with similar mods seem to come up in the $6-$8k range in my experience. high mileage, odd mod combination, and unknown history. if the block and turbo are verified good(compression/leak down/oil analysis), and t-belt/water pump service was done on time, and the trans shows no signs of slipping, then the car may be worth up to $6K. Link to comment Share on other sites More sharing options...
Mluetch Posted May 13, 2019 Author Share Posted May 13, 2019 Everything checked out and service is up-to-date. Thanks for your reply. Link to comment Share on other sites More sharing options...
