basket_case Posted April 27, 2019 Share Posted April 27, 2019 This might be so obvious that I can't see it, but where do I log off/sign off? Link to comment Share on other sites More sharing options...
Notorious Posted April 27, 2019 Share Posted April 27, 2019 Depends on which “theme” you’re using. On the vB default theme, it is located under the “Welcome, Username” on the top right corner. You can select the theme for the forums on the very opposite corner on the bottom left corner. Link to comment Share on other sites More sharing options...
basket_case Posted April 28, 2019 Author Share Posted April 28, 2019 Thanks. I was using v3.0 but when I switched to the default, I can definitely find the log out. Link to comment Share on other sites More sharing options...
