CT: 2005 Legacy GT Ltd. Wagon 6sp in SWP
Soarer
Year, Make and Model: 2005 Subaru Legacy GT Limited Wagon
Color: Satin White Pearl
Miles: 167,XXX on chassis... Less than 30k on motor and most major components
Transmission: 6 Speed Manual Version 7 STi
Title: Clear - no accidents
Lien: No liens
VIN: 4S3BP676656314564
Seller's email address: cdwauto at iCloud.com
Asking Price: $14,999 OBO
Please email me for more pics. This site is VERY difficult to upload pics to. I have over 50 pics of the car and I can share an online album with you of them.
This is one of just 61 Limited wagons produced in 2005 in Satin White Pearl with tan interior and a manual transmission. As you likely know if you’re looking at this car, 2005 was the only year Subaru imported a manual transmission 2.5GT wagon to the US. I purchased the car from the original owner at 132k. He had done a lot of maintenance and some minor modifications mainly to wear items as they needed to be replaced.
After I purchased the car, I drove it for about 7500 miles before pulling it all apart for my build. I have owned about 30 WRXs and 9 Legacy GTs so I know my way around these cars. My vision was to build a reliable daily driver that that could do everything. I wanted a 4 season car that could perform, look good, had tons of utility and was NOT an automatic. I didn’t want to sacrifice driveability for performance. I have heard way too many horror stories of people buying built motors only to have them fail after 5 or 10k miles so, I decided to go with a brand new OEM EJ257 factory short block (luckily I got a BB/BB block) from Subaru and tune it to power numbers that were proven not to over-stress the motor and could give it the longevity I was looking for. I settled on 330whp as my target and built the package around that. The car is totally balanced and dialed in right now.
The car was tuned by Mike Botti at ACI Dynamix in Seymore CT. It put down 322hp and 341tq on the hottest most humid day of 2017. Peak boost is 19.5psi tapering to 18psi. There is lots more in this engine if you want to push it but I never did. It's plenty powerful enough as it is. It's tuned conservatively. The boost comes on gradually and smoothly for engine longevity.
Clean CT title in hand with no liens. Non-smoker car that has been well taken care of. AC, heat, cruise control and all other power options all work exactly as they should. Sunroof does not leak and slides smoothly. I have a 3” thick file of receipts and records for this car. No accidents and clean Carfax. I have an OEM catted downpipe that comes with the car and can easily be swapped in for anyone that needs to deal with emissions testing. This car passed CT emissions without a cat just last year. If you’re looking for a turn-key car that can do everything, come and take a look at this one. All the work has been done and this car is ready for another 150k of use.
Motor:
New EJ257 short block at 139k
New 12mm oil pump at 139k
New oil pan at 139k
New EJ257 oil cooler at 139k
New PCV valve and hoses at 139k
New coolant hard pipe at 139k
New Subaru Head Gaskets at 139k
B25 Cylinder Heads cleaned, checked for cracks and straightness, valves lapped, tested for leaks, cams & buckets shimmed, Brian Crower valve springs and retainers installed, new valve seals
New ACVS solenoids at 139k
New valve cover gaskets at 139k
New cam seals at 139k
New Group N motor mounts at 139k
New Gates racing timing belt at 139k
New Gates water pump at 139k
New timing idlers & pulleys at 139k
New power steering and alternator belts at 139k
Power steering pump rebuild at 160k
ARP head studs at 139k
New front oxygen sensor at 139k
New rear oxygen sensor at 139k
TGV Deletes at 139k
GrimmSpeed electronic boost control solenoid
Power steering flush at 160k
New thermostat at 160k
New coolant temperature sensor at 160k
Coolant flush at 160k
TurboSmart recirculating blow off valve
TurboSmart wastegate actuator
Infamous Performance turbo oil line filter kit
Billet SPT battery tie down
Billet SPT oil cap
Magnetic drain plug
Exhaust:
Helix crossover pipe, heatwrapped & shrouded
Heatwrapped & shrouded OEM manifolds
New heatwrapped Invidia catless up pipe at 139k
New Invidia catless down pipe at 145k
Stainless steel flex joint added to downpipe to allow for exhaust movement
SPT v2 cat back exhaust
Fuel:
Deatschwerks DW65c fuel pump
Injector Dynamix top feed injector conversion rails
Injector Dynamix 1000cc top feed injectors with correct couplers crimped to factory intake harness
Custom fuel lines with multiple dampers
Induction:
GrimmSpeed TMIC with gold heat reflection tape
K&N Typhoon intake
Gimmick silicone turbo inlet
BNR 18G Turbo
Cobb turbo heat shield
Driveline:
JDM V7 STi 6 speed manual transmission installed at 139k and had under 40k on it then
Exedy organic clutch disc at 139k
Exedy pressure plate at 139k
STi OEM flywheel resurfaced at 139k
JDM v2 R160 Mechanical Limited Slip rear differential
Custom hybrid axles with new boots rebuilt at 139k
New Front & Rear wheel bearings/hubs at 139k
Poly shifter bushings at 139k
Suspension:
RaceComp Engineering Tarmac 1 Coilovers
All new OEM front & rear suspension bushings at 139k
Perrin 22mm rear sway bar
Perrin rear sway bar stiffener brackets
Perrin front sway bar
New front sway bar bushings at 155k
New Group N front sway bar end links at 139k
New OEM steering rack boots at 139k
New ball joints at 139k
Brakes:
StopTech front Big Brake Kit
New StopTech slotted front rotors at 165k
New Hawk street front pads at 165k
New rear pads & rotors at 155k
Motul brake fluid flush at 165k
Interior:
AutoMeter boost gauge
AutoMeter EGT gauge
AutoMeter LED backlight dimmer switch for gauges
AEM wideband AFR gauge
CubbyPod for boost and AFR gauges
DashPod for EGT gauge
2012 STi driver seat (original tan leather seat in very good condition also included)
Jazzy stereo input with hardwire for iPhone lightning cable
HomeLink auto-dimming rear view mirror with 3 garage door opener buttons
Extended armrest
Hardwired DashCam
Hardwired radar detector power source
OEM trunk mat
OEM subwoofer
OEM rear cargo cover
OEM trunk mat
2 sets of keys with remotes
New OEM 6sp shift knob at 150k
Exterior:
2004 STi BBS goldies
225/45/17 Continental ExtremeContact DWS tires with 65% tread remaining
STi style front lip
Thule bike rack
Lightly tinted windows
Hella Supertones
I know there are a lot of things that I'm forgetting too!
Cons: I can’t say that anything is really wrong with it but I’ll list things that are less than perfect.
There are some acorn dings on the roof. There is a black stain on the inside of the hatch trim piece. Some of the plastic interior pieces have nicks and scratches on them in line with a car of this vintage. The body has its share of small imperfections. It looks like a 10 out of 10 at 20 feet but is really an 8 out of 10 when you get up close. However, there is NO rust on the body at all which is incredibly rare for a Subaru of this age.
This car is 100% ready to go. I can confidently say that I would drive it across the country tomorrow without worrying at all. The suspension is firm but not uncomfortable like most coilover setups. I retained the factory rubber strut mounts which make a huge difference. Also, the RaceComp Engineering coilovers on this car are made from stainless steel so the collars don't freeze to the threads after one winter. They are totally rebuildable as well.
I have taken exceptional care of this car and fixed any issues as soon as they came up. I can say that at this point, I've got the car totally sorted out and it is a real pleasure to drive. It's not loud and obnoxious at all. It drives mildly when you just want to commute smoothly which is how I put the majority of the miles on it. The turbo spools up early with very little lag and it pairs perfectly with the close ratio JDM 6sp to keep the motor in its' powerband.
The StopTech big brakes are virtually endless and have lots of bite. The pedal is firm has very little play before the brakes pick up. Shifts are very crisp and there is no grinding or funny noises coming from the gearbox.
I am not interested in any trades. Cash, cashiers check or wire only. If you need to get financing for this car, please don't waste my time. Get your money lined up before calling me. I am willing to ship this car at the buyer's expense. No brokers, no low ballers and no scammers.
I have always bought cars based on their condition, no their mileage. Mileage only tells part of the story of a car. Although there is 167k on the chassis of this car, every wear item and major component has been replaced or rebuilt with OEM or high quality aftermarket parts within the past 30k. There are no oil leaks. The motor purrs with no knocking, piston slapping, valve ticks or smoke. Since the car is freshly rebuilt, all the fasteners come off easily with no frozen or rusted bolts. Great care was taken in the building of this car. I've got over $30k into this car not including all my labor.
The car is located in Danbury, CT near the mall. If this ad is still up, the car is still available.
  • 2 weeks later...
Also, FYI.... the first 7500 miles on the new motor were on a break-in tune running very low boost. I was chasing down a few issues at the time and didn't want to tune for power until everything was sorted. The issue turned out to be a leaky injector. The injectors were all sent to Injector Dynamix, cleaned and flow tested. I never had a problem after that with them.
Quick question, I noticed you put R160 rear diff, how come you didn't go up to a R180?
Thanks!
Good question.... There are a few reasons.
#1 I had a mechanical R160 LSD on hand and a ring and pinion set to match ratios was easy to find
#2 If I used a R180, I'd have had to use the larger axles and corresponding hubs.
#3 An R180 is overkill for my application. An R160 can hold 450+WHP and I had no plans on pushing it that hard. The MLSD gives great feel and performance.
#4 An R180 and the corresponding components add a lot of weight compared to the R160 which is sized just right for my application
  • 2 weeks later...
