SSpeed Posted April 15, 2019 Share Posted April 15, 2019 (edited) Looking for ideas on what to do while the engine is out. '05 LGT 153k miles - near perfect compression and leakdown Trans coming out for a noisy bearing and possible broken tooth on second And my front main seal is leaking badly Here's what I had considered: 11831AA210 - Oil seperator plate (but looks like advice is to leave it?) Oil pump Oil pump o-ring Front main seal Cylinder head plugs (half moons) - 11051AA070 x 2 Left and right valve cover - 13272AA140 & 13270AA190 Spark plug hole gaskets - 13293AA051 x 4 Oil cooler gasket - 21370KA001 Cam seals - 806732160 x 2 and 803742160 x 2 Rear main seal - 806786040 Re-seal oil pan Check harmonic balancer Machine WRX flywheel Dominator 1.5 XT-R since turbine housing is always the hardest part to get past, why put my old BNR 16g back on? Just had the intake manifold and such off recently, so those gaskets are good. Should I also do those valve cover breather gaskets? Any other o-rings that will be hard as rocks that I should consider? Edited April 15, 2019 by SSpeed Link to comment Share on other sites More sharing options...
Max Capacity Posted April 16, 2019 Share Posted April 16, 2019 Vacuum hose, heater hoses, have you replaced the intake hose to the turbo ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SSpeed Posted April 16, 2019 Author Share Posted April 16, 2019 Yeah, I have a Perrin inlet on it. Did all vacuum hoses not long ago. Hadn't thought about heater hoses. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 20, 2019 Share Posted April 20, 2019 Coolant cross over pipe ? I guess you've looked through my click here link in my sig. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
