djemzine Posted April 13, 2019 Share Posted April 13, 2019 Hey guys, So my 07 Legacy 2.5i wagon needs the following replaced. I wanted to know if these fit the NA USDM wagon. 1) JDM Subaru Impreza WRX STi Aluminum Lower Control Arms Legacy Forester 1993-2007 - comes with ball joints. These are for the front 2) JDM Subaru Legacy Rear Trailing Arms Control Lateral Links Transverse 2005-2009 The prices are reasonable for these, and the mileage on my Legacy is 220,000 KMs. Basically I need to have my front lower control arm bushings changed out, my front and rear sway bar end links, and rear trailing arm bushings. In addition, the front left axle/CV shaft. Link to comment Share on other sites More sharing options...
djemzine Posted April 19, 2019 Author Share Posted April 19, 2019 Anyone? Link to comment Share on other sites More sharing options...
Notorious Posted April 19, 2019 Share Posted April 19, 2019 Why get the JDM parts if they’re most likely used anyways? Why not get new OEM or aftermarket bushings that will for sure last longer and give no issues? Unless what you’re buying is new... Link to comment Share on other sites More sharing options...
ehsnils Posted April 20, 2019 Share Posted April 20, 2019 OEM Bilstein suspension - like the Spec B. Europe had a Spec B wagon with the 3.0 H6. Link to comment Share on other sites More sharing options...
05MNLGT Posted April 22, 2019 Share Posted April 22, 2019 (edited) Hey guys, Basically I need to have my front lower control arm bushings changed out, my front and rear sway bar end links, and rear trailing arm bushings. In addition, the front left axle/CV shaft. oem bushings have no difference from usdm to jdm/edm in legacy wagons. some of the s402 bushings are different, but they are expensive to import or are impossible to find. i use all AVO bushings in my wagon. i have a aggressive setup. if your just DD with some spirit, OEM is fine. aftermarket bushings. poly. less expensive and stronger then oem aftermarket sway bar links. better options for adjustability oem left axle. Edited April 25, 2019 by 05MNLGT Link to comment Share on other sites More sharing options...
