krellmk Posted April 1, 2019 Share Posted April 1, 2019 My 2017 Legacy headlights won't shut off if I'm sitting in the car with engine off.. switch is in auto. Link to comment Share on other sites More sharing options...
Syzygy05 Posted April 1, 2019 Share Posted April 1, 2019 They should turn off after a few minutes. How long does it stay on? Link to comment Share on other sites More sharing options...
SubieN8 Posted April 1, 2019 Share Posted April 1, 2019 If you leave the key in the ignition, the lights will not shut off when in Auto mode. Link to comment Share on other sites More sharing options...
krellmk Posted April 1, 2019 Author Share Posted April 1, 2019 Waited for 15 minutes lights never turn off , no key in the ignition push button start. Link to comment Share on other sites More sharing options...
gathermewool Posted April 1, 2019 Share Posted April 1, 2019 What do you mean there's, "no key in the ignition push button start"? Is it keyless or keyed? Are all of the dash lights and indicators off when this occurs? What does your owner's manual say??? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
krellmk Posted April 1, 2019 Author Share Posted April 1, 2019 Keyless and all dash lights and indicators off ..don't see anything in the manual on this problem. Link to comment Share on other sites More sharing options...
crudzinskas Posted April 1, 2019 Share Posted April 1, 2019 From the Manual 3-48: The low beam headlights will turn off under any of the following conditions. . 3 minutes have passed since the low beam headlights were illuminated by the welcome lighting function. . 30 seconds have passed since the door is opened and closed.*1 . The light control switch is turned to a position other than “AUTO”. . The locking procedure is performed twice. When performing the unlocking procedure after performing the locking procedure, perform the locking procedure twice again. If the car is off, I have never had the headlights remain on for more than the time I set up using the i/set toggle switch on the steering wheel. You should contact your dealer about this, especially if you are under warranty still. Link to comment Share on other sites More sharing options...
SubieN8 Posted April 1, 2019 Share Posted April 1, 2019 Did you leave the fob in the car or near it? If so, that may be the issue. Link to comment Share on other sites More sharing options...
krellmk Posted April 2, 2019 Author Share Posted April 2, 2019 Fob was in my pocket while i sat in the car, only had this car for a few days Link to comment Share on other sites More sharing options...
MrCobbs Posted April 2, 2019 Share Posted April 2, 2019 Try to get out and walk away about 20 feet then press the lock button twice to see if the lights go off. Also while walking away from the car and closing the door, see if you notice a constant beep and that all doors and the trunk is actually closed completely. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
hkshooter Posted April 2, 2019 Share Posted April 2, 2019 Read the manual, lights won't time out until the door opens then closes. Link to comment Share on other sites More sharing options...
krellmk Posted April 2, 2019 Author Share Posted April 2, 2019 Will try the door thingy this weekend Link to comment Share on other sites More sharing options...
Syzygy05 Posted April 2, 2019 Share Posted April 2, 2019 I've also sat in the car after turning the engine off and headlights on. They usually turn off within 3 minutes. I'll test it today and let you know what happens and what I did. Link to comment Share on other sites More sharing options...
