scott6058 Posted December 26, 2018 Share Posted December 26, 2018 All flashing lights on the dash and code reader states bank one o2 sensor id faulty. Curious which one is bank one. Is it the one visible below the intake filter or the one slightly to the rear also visible from the engine compartment? Also are the interchangable as I already replaced the front thinking it is bank one. The lights didnd quit. cruise contron CEL traction control..... Thanks for anyones help.;( Best regards Scott Link to comment Share on other sites More sharing options...
poconoracing Posted December 26, 2018 Share Posted December 26, 2018 What’s the code? It should read something like P0130 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 1) or P0136 Oxygen Sensor Circuit Malfunction (Bank 1 Sensor 2) Sensor 1 is upstream from the cat. Sensor two is downstream of the cat Link to comment Share on other sites More sharing options...
scott6058 Posted December 26, 2018 Author Share Posted December 26, 2018 P0032 Link to comment Share on other sites More sharing options...
scott6058 Posted December 26, 2018 Author Share Posted December 26, 2018 P0034 appreciating any help. Sorry p0032 Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
poconoracing Posted December 26, 2018 Share Posted December 26, 2018 Sorry p0032 Sent from my iPhone using Tapatalk This is from the 2010 legacy 2.5 service manual. The car is telling you there is an issue in the wiring between the ECM and the upstream 02 sensor E: DTC P0032 HO2S HEATER CONTROL CIRCUIT HIGH (BANK 1 SENSOR 1) DTC DETECTING CONDITION: • Immediately at fault recognition • GENERAL DESCRIPTION <Ref. to GD(H4SO)-15, DTC P0032 HO2S HEATER CONTROL CIRCUIT HIGH (BANK 1 SENSOR 1), Diagnostic Trouble Code (DTC) Detecting Criteria.> Diagnostic Procedure with Diagnostic Trouble Code (DTC) ENGINE (DIAGNOSTICS) Step Check Yes No 1 CHECK HARNESS BETWEEN ECM AND FRONT OXYGEN (A/F) SENSOR CONNECTOR. 1) Turn the ignition switch to OFF. 2) Measure the voltage between ECM and chassis ground. Connector & terminal (B136) No. 5 (+) — Chassis ground (–): (B136) No. 6 (+) — Chassis ground (–): Is the voltage 10 V or more? Repair the short circuit of harness to power supply between ECM and front oxygen (A/F) sensor connector. Go to step 2. 2 CHECK GROUND CIRCUIT FOR ECM. 1) Disconnect the connector from ECM. 2) Measure the resistance between ECM and chassis ground. Connector & terminal (B134) No. 3 — Chassis ground: (B134) No. 4 — Chassis ground: (B134) No. 6 — Chassis ground: (B137) No. 1 — Chassis ground: (B137) No. 3 — Chassis ground: Is the resistance less than 5 ? Repair the poor contact of ECM connector. Repair the harness and connector. NOTE: In this case, repair the following item: • Open circuit of harness between ECM and engine ground • Poor contact of coupling connector I attached a .pdf of the pagesp0032.pdf Link to comment Share on other sites More sharing options...
scott6058 Posted December 26, 2018 Author Share Posted December 26, 2018 Thank you very much I'll report back as to what I find. Scott Link to comment Share on other sites More sharing options...
Tronic Posted December 26, 2018 Share Posted December 26, 2018 Usually the pre-heater goes open circuit but the O2 sensor itself still works. This is really not a big problem in itself, however you really want the engine checklight to stay off in case there another separate problem develops.. Link to comment Share on other sites More sharing options...
ripstik Posted January 2, 2019 Share Posted January 2, 2019 Usually the pre-heater goes open circuit but the O2 sensor itself still works. This is really not a big problem in itself, however you really want the engine checklight to stay off in case there another separate problem develops.. heater circuit on bank 1 sensor 1 (AFR sensor) of my GF's 3.6 outback went out, relatively common if your taking a lot of short trips and not really getting up to temp. you will see reduced gas mileage until the sensor itself warms up, but that's about it. on subies bank 1 is the passenger side because japan, but i think the 2.5i's only have one set of oxygen sensors. Link to comment Share on other sites More sharing options...
