KevinR Posted December 18, 2018 Share Posted December 18, 2018 Hello I have an 05 outback xt auto. I noticed that it was running strange this morning with no cel. Ran strange on the way home too. On the WY home I pulled up the torque app and saw that I'm running lean like 11.1 under boost and 20 at idle. In the next few days I'll check vacuum lines. Is there anything else I should check out. Thanks for your time. Kevin Link to comment Share on other sites More sharing options...
relative4 Posted December 19, 2018 Share Posted December 19, 2018 Since you have Torque, chances are you have a dongle that supports the BtSSM app. If so, buy that and post your learned values. Link to comment Share on other sites More sharing options...
awfulwaffle Posted December 19, 2018 Share Posted December 19, 2018 (edited) I think you have that backwards. 11.1 is richer than stoichiometric (14.7), and 20 is leaner. Remember, AFR is the air/fuel ratio, so the more air you have the higher the value will be. That said, 20 at idle is not normal. When you're not touching the throttle or engine braking, your AFR should be in the 14s, with 14.7 being the target in most cases. ~11 is what you should see under boost on the stock AF sensor in the factory location. Edited December 19, 2018 by awfulwaffle Link to comment Share on other sites More sharing options...
KevinR Posted December 19, 2018 Author Share Posted December 19, 2018 What is and how to use the BtSSM app? Link to comment Share on other sites More sharing options...
Perscitus Posted December 19, 2018 Share Posted December 19, 2018 What is and how to use the BtSSM app? https://www.btssm.com/ https://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-v-2-267811.html?highlight=btssm https://legacygt.com/forums/showthread.php/btssm-bluetooth-adapter-app-v-1-closed-229709.html?t=229709&highlight=btssm+v-1 Link to comment Share on other sites More sharing options...
