madrig Posted November 26, 2018 Share Posted November 26, 2018 i m reaching to people that know about electrical . my goal is to use a switch to disconnect the ABS during some situation in winter . it is too scary too drive sometime in snow storm with the abs . i usually pull up the fuse , but will like too have something more easy , turn on and off as desired . the way i thinking is to use a relay to cut the main power of the abs module . i want to use the switch of the traction control . but i need to find the wiring also for this switch . can someone draw me a wiring diagram how to to this . also what is the interference between abs , brake booster and idle . it happen that the car stall when i brake hard and keep it in the bottom when abs is disconnected . Link to comment Share on other sites More sharing options...
madrig Posted November 26, 2018 Author Share Posted November 26, 2018 https://www.youtube.com/watch?v=2-PA5vF8jn0 check this video , at 7 minute . audi have it back in the days ! Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 26, 2018 Share Posted November 26, 2018 If you're pulling the fuse now, just run a wire from each side of the fuse receptacle to a switch and put a fuse in the hot side of the line. Link to comment Share on other sites More sharing options...
madrig Posted December 10, 2018 Author Share Posted December 10, 2018 If you're pulling the fuse now, just run a wire from each side of the fuse receptacle to a switch and put a fuse in the hot side of the line. i want to use , if possible , the button of the vdc disconnect , from what i understand the switch send power when you press , it s not an on off switch , so i need a relay , that will be actuated open and stay open , send power again and close . so i dont know wht it s called , and this is what i understand ,i can not be trusted in electrical ! Link to comment Share on other sites More sharing options...
madrig Posted December 10, 2018 Author Share Posted December 10, 2018 i compared module from usdm , edm and jdm . all the same . Link to comment Share on other sites More sharing options...
madrig Posted December 10, 2018 Author Share Posted December 10, 2018 so i have the plug from a jdm unit , so i have to investigate the wiring . compared to my plugs . one green wire more on the usdm all good here difference here . of course i do not have folding mirror and vdc but look like vdc is wired on my usdm 2005 ! Link to comment Share on other sites More sharing options...
