09Legacy01 Posted November 15, 2018 Share Posted November 15, 2018 Looking to run diagnostics on my 09 Subaru Legacy. I have been having issues with it during the cold months and it's starting again. I have changed the crank position sensor to the fuel pump and other things in between and still have issues. Brand new interstate battery checked along with my alternator apparently working perfectly. Any suggestions?? Thanks Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted November 15, 2018 Share Posted November 15, 2018 What are the symptoms, does it not start at all sometimes? Slow to start? Link to comment Share on other sites More sharing options...
09Legacy01 Posted November 19, 2018 Author Share Posted November 19, 2018 Cranks strong, all lights working fine inside, after about 3 or 4 trys they start to dim and the battery begins to die. Just changed the plugs and wires today so we shall see tomorrow morning. Plugs didnt even look bad when I removed them I am thinking I will need to have a diagnostics run at this point Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
09Legacy01 Posted November 19, 2018 Author Share Posted November 19, 2018 It will usually start after i wait a few minutes and try again but yesterday it did not I had to jump it. Battery and alternator came back checked out working fine. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
apexi Posted November 19, 2018 Share Posted November 19, 2018 Are the battery connections clean and tight? On my car there was some kind of black plastic spacer from the factory that limited how tight I could get the negative terminal, and when I switched to an aftermarket battery it would not tighten down enough with that thing installed. Probably not the culprit, but just something I thought I'd throw out there, never know. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 19, 2018 Share Posted November 19, 2018 here's the service manual, http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
