wraedeohed Posted November 3, 2018 Share Posted November 3, 2018 Finally getting around to this since I'm under the Brute today. Just not exactly sure where my GFB DV valve is going since the turbo is under the front. And the fact that I've never don't this before. Is this section the right area? Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
Sarang Posted November 3, 2018 Share Posted November 3, 2018 It's on the top of that black intake tube going in to the turbo. It connects to the charge pipe just above the outlet of the turbo. I would access it from the top. Remove the one radiator fan to make room. Somebody did an install thread on here somewhere, I didn't come up with that myself. Link to comment Share on other sites More sharing options...
wraedeohed Posted November 3, 2018 Author Share Posted November 3, 2018 Found it... Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
cww516 Posted November 3, 2018 Share Posted November 3, 2018 Yep, there's plenty of room to get in from the top, just pull the passenger's side fan out first. I do seem to recall something being easier from below, although I had the flexy pipe out trying to replace it with other things in order to get a Synapse DV to fit the stock location (which didn't work). Link to comment Share on other sites More sharing options...
FLlegacy Posted November 3, 2018 Share Posted November 3, 2018 The boost control solenoid is easier from below, but yeah do the bpv from above. Link to comment Share on other sites More sharing options...
wraedeohed Posted November 3, 2018 Author Share Posted November 3, 2018 Other than the two clamps for the hose, and the hose clamp on the side what the hell else is holding this thing on... I can't seem to get it loose. Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
wraedeohed Posted November 3, 2018 Author Share Posted November 3, 2018 I have the hose clamp to the right fully loose, the two clamps at the bottom are loose too... Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
wraedeohed Posted November 3, 2018 Author Share Posted November 3, 2018 Nevermind, got it, just old grit and surface tension. [emoji849] Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted November 3, 2018 Share Posted November 3, 2018 Yeah it is not easy to take off the first time. Link to comment Share on other sites More sharing options...
wraedeohed Posted November 3, 2018 Author Share Posted November 3, 2018 Just took Brutus for a test run, boost definitely seems strong and spooling quicker. I feel like there's much less lag than before. The install sucked though for sure. As far as the preload setting goes, I found this video useful. Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
