Hatch won't lock... Help?
Hello all, I just recently purchased an LGT wagon (woot) and I'm currently sorting out a few of its minor issues. One of them is that the rear hatch won't lock. The key fob and the switch on the door lock all the door except the hatch. Doesn't seem like a mechanical issue, as I don't hear any sounds coming from the hatch door when locking. Not sure if this has been posted about before, apologies if it has, I'm very new to the forum. Thanks!!
-M
Google that problem, I'm sure you'll find links to threads on here.
There was someone a couple weeks back with the same type issue.
There is a lever behind the panel on the inside of the hatch.
You may have a broken wire, a common problem, in the grommet on the top right side of the hatch hinge.
I had my harness replaced my my buddies body shop a few years back.
Here's the service manual,
http://people.csail.mit.edu/ilh/vacation/
Engine Build - Click Here
