bugblatterbeast Posted November 7, 2005 Share Posted November 7, 2005 I'm just curious if anyone else has brake hoses that look this bad after a couple months of use? Link to comment Share on other sites More sharing options...
mccorry Posted November 7, 2005 Share Posted November 7, 2005 Are you sure the hose is cracked... and not the undercoating layer that is on them? Link to comment Share on other sites More sharing options...
BDII Posted November 7, 2005 Share Posted November 7, 2005 I think the break line has a sleeve over it. I will have to look, but im sure it does. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Opie Posted November 8, 2005 Share Posted November 8, 2005 It's the undercoating flaking of the rubber lines...no biggie Link to comment Share on other sites More sharing options...
castor Posted November 8, 2005 Share Posted November 8, 2005 Ditto Link to comment Share on other sites More sharing options...
bugblatterbeast Posted November 9, 2005 Author Share Posted November 9, 2005 thanks guys. I'm going to have a closer look when I get around to swapping to winter tires this weekend. the reason I suspect the lines is I made sure they were masked when I undercoated the car. that being said, I couldn't get real close to inspect the lines last weekend. Link to comment Share on other sites More sharing options...
bugblatterbeast Posted November 17, 2005 Author Share Posted November 17, 2005 it's confirmed. the outer sleeve is cracked and peeling.... oh well its only cosmetic. Link to comment Share on other sites More sharing options...
mccorry Posted November 17, 2005 Share Posted November 17, 2005 Ew... that shouldn't happen. Link to comment Share on other sites More sharing options...
