cmac1130 Posted September 1, 2018 Share Posted September 1, 2018 I just installed accessport on my 07 lgt and around 4200 rpm or so theres a blip in the power, just wondering if any one had any ideas or a similar problem thanks Link to comment Share on other sites More sharing options...
relative4 Posted September 1, 2018 Share Posted September 1, 2018 I just installed accessport on my 07 lgt and around 4200 rpm or so theres a blip in the power, just wondering if any one had any ideas or a similar problem thanksStage 1? Post a log? Link to comment Share on other sites More sharing options...
cmac1130 Posted September 1, 2018 Author Share Posted September 1, 2018 stage one yes, https://docs.google.com/spreadsheets/d/e/2PACX-1vQCnfCJcA-0_lyHDzbJyz2zE7WYkg6jV2MzzqblMGDyo19LJ9HRiHXwn3llLFai-AiQrGaQ26TRTXCt/pubhtml Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted September 2, 2018 Share Posted September 2, 2018 I took a look at your log, and it's huge... I'm still learning how to analyse log data but it appears to me that despite throttle input, your calculated load seems to peak out at 1.65 and boost pressure does not build over 9.3lbs. Your DAM looks great, though I also see fbkc at 69.xx seconds at low load which is pretty normal as far as I know. Boost on a stock tune should reach 11.5 or 13.5psi depending on who you ask (Cobb Stg 1 should hit 15.5psi @ peak) and peaked out calculated load on a healthy motor should get you to somewhere around 2.5x- 2.6x in my experience. Boost leak test maybe? Link to comment Share on other sites More sharing options...
cmac1130 Posted September 2, 2018 Author Share Posted September 2, 2018 thanks a lot the guy who works on my car is a suby tech, ill get in touch with him, im just curious cause before i added to ap, the car was a lot smoother . i just had new spark plugs and a oil change the day before i went to the ap, maybe that has somthing to do with it Link to comment Share on other sites More sharing options...
Max Capacity Posted September 3, 2018 Share Posted September 3, 2018 Have you tried to un-marry the Cobb and reload it ? May be drive it at "back to stock" before you reload it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmac1130 Posted September 7, 2018 Author Share Posted September 7, 2018 yes i unmarried it and it ran the same way with out the ap, installed it again and now i am only hitting 9.5 on boost Link to comment Share on other sites More sharing options...
relative4 Posted September 7, 2018 Share Posted September 7, 2018 What are your A/F learning values in the A-C ranges? Can you post a short log from when the problem is happening? Just from the sequence of events, it sounds like you sprang a boost leak when you went from stock boost to stage 1 levels. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2018 Share Posted September 8, 2018 check over the connections at the tmic to throttle body, that's the first place that will blow off or leak, but that normally is pretty noticeable. To do a boost leak, I use a pint size paint can to plug the hose off the air filter box, pull the small hose off the blow off valve, give that hose a short blast of air from a compressor, put your thumb over the hose, listen for leaks. The front corner of the stock tmic over the turbo is another spot that leaks. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmac1130 Posted September 8, 2018 Author Share Posted September 8, 2018 yeah i sent my data logs to my mechanic and his tuner, it is def a vacuum. boost leak, getting it fixed next week, thanks for all the input Link to comment Share on other sites More sharing options...
cmac1130 Posted September 9, 2018 Author Share Posted September 9, 2018 https://docs.google.com/spreadsheets/d/1djg49EvWSdcsrX61rPGt39-xUmFfMxpnUsbl7Eat6bY/edit?usp=sharing Link to comment Share on other sites More sharing options...
relative4 Posted September 10, 2018 Share Posted September 10, 2018 Wow, that is a massive vacuum leak. Barely driveable. What's A/F learning at idle? A leak that big should be easy to find visually or with the ol' spray test. Link to comment Share on other sites More sharing options...
cmac1130 Posted September 23, 2018 Author Share Posted September 23, 2018 ended up with a tear in the inlet pipe to the turbo, and a bad connection from the throttle body to intercooler Link to comment Share on other sites More sharing options...
