swells Posted August 1, 2018 Share Posted August 1, 2018 I have noticed a small oil leak on the driveway under my Subie. It has 80K miles. Not sure where the oil is coming from. Any suggestions where to start looking? Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 1, 2018 Share Posted August 1, 2018 since you know it is the CVT, use the extended warranty to sort it out. Link to comment Share on other sites More sharing options...
cww516 Posted August 1, 2018 Share Posted August 1, 2018 Just to get the smart-ass answer out of the way first, under the car would be a good place to start looking On a more helpful note, what color is it? Preferably the fluid itself and not the stain. Wondering if it's engine oil or something else (CVT, power steering, etc.). Link to comment Share on other sites More sharing options...
swells Posted August 2, 2018 Author Share Posted August 2, 2018 Just to get the smart-ass answer out of the way first, under the car would be a good place to start looking On a more helpful note, what color is it? Preferably the fluid itself and not the stain. Wondering if it's engine oil or something else (CVT, power steering, etc.). Thank you. I did find it under the car. It is clear or light colored and oil feeling. I washed the under carriage and can't find the leak. I had just changed the oil two weeks ago with Amsoil. So the oil is very clean. The location on the driveway appears to be the front of the engine area. When I checked the dip stick it was over filled so I pumped out about 1/2 a quart and now it is the right level on the stick. I was thinking maybe there is an overfill tube or something. I love the car but worry about all the threads on oil problems with these cars. Link to comment Share on other sites More sharing options...
swells Posted August 2, 2018 Author Share Posted August 2, 2018 since you know it is the CVT, use the extended warranty to sort it out. What is the extended warranty on the CVT? Link to comment Share on other sites More sharing options...
FLlegacy Posted August 2, 2018 Share Posted August 2, 2018 The extended cvt warranty is 8 years unlimited mileage IIRC. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 2, 2018 Share Posted August 2, 2018 1 year unlimited mileage for all cars that ended already 10 years or 100K for any of the following cars 2010-15 Legacy and Outback; 2015 Legacy and Outback with 3.6 liter V-6; the 2012-15 Impreza; 2013-15 Crosstrek; 2014-15 Crosstrek Hybrid; 2014-15 Forester with 2.5 liter four-cylinder; 2014-15 Forester with turbocharged 2.0 liter four cylinder and 2015 WRX 2.0. Link to comment Share on other sites More sharing options...
swells Posted August 3, 2018 Author Share Posted August 3, 2018 I'm guessing the valve cover gasket or oil cooler "O" ring. Link to comment Share on other sites More sharing options...
ArmyVetMP Posted August 3, 2018 Share Posted August 3, 2018 If the oil was overfilled, there is a possibility that it over pressurized the system and forced some oil out some way? Link to comment Share on other sites More sharing options...
swells Posted August 3, 2018 Author Share Posted August 3, 2018 I think I found the leak. It was the washer on the oil drain plug. It was hard to find because it just hit the ground and did not hang to the pan. Link to comment Share on other sites More sharing options...
cww516 Posted August 4, 2018 Share Posted August 4, 2018 Glad it was something simple! Also, for whatever it's worth, you'd have to WAY overfill the engine to start blowing oil out through a seal somewhere. They'll take 5 full quarts no sweat. Link to comment Share on other sites More sharing options...
swells Posted August 6, 2018 Author Share Posted August 6, 2018 So has anyone used Lucus oil treatment? I am using Amsoil was thinking about adding some Lucas. Thoughts? BTW after the weekend no more oil spots on the ground. Link to comment Share on other sites More sharing options...
