stewdogg Posted July 26, 2018 Share Posted July 26, 2018 I have been looking to replace my mushed out stabilizer bar bushings and having a tough time finding stuff for the stock set up. I did find these AVO bushings, but they are out of stock everywhere. https://www.maperformance.com/products/avo-front-sway-bar-bushings-for-23mm-stabilizer-bar-10-13-subaru-legacy-gt-s1x10m1gv023t I contacted maperformance and they said the bushings are special order and they are able to get them, but will take a couple of weeks to get them in. Just putting this out there if anyone wants a set and wants to get in on the stock order when I order mine? I guess if anyone knows if these will or won't fit my Leggy, that would be appreciated as well. Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 26, 2018 Share Posted July 26, 2018 Go with CKE SSP bushings. They're molded directly from OEM bushings so they're literally perfect OEM fit, but are a stiffer durometer urethane, and he has several durometers available to chose from. Covers tons of OEM Subaru sizes too. Available on ebay, the maker of them is also a member here (traildogck I believe it is). If you're still on stock sway bars, you need 24mm front and 16 mm rear, I'll put links to his below. Also if you ever decide to upgrade to the larger OEM bars (26mm FSB from 2013 Legacy and 20mm RSB from 15+ STI), he offers bushings for those as well. Pretty much any OEM sway bar bushing design is available. Really excellent product, huge improvement in feel. 24mm Front: https://www.ebay.com/itm/173069059279 16mm Rear: https://www.ebay.com/itm/173347733959 Store: https://www.ebay.com/usr/teleguyck?_trksid=p2047675.l2559 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
stewdogg Posted July 26, 2018 Author Share Posted July 26, 2018 Thanks Humble! And that's a shinning example of why this place is so awesome! I'm also going to buy some new end links, you got anything for those? I was just looking at the Perrin polyurethane links because I'm not so sure about those OEM Moog links. Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 26, 2018 Share Posted July 26, 2018 PM'ing you actually, may have something on hand you might be interested in. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Perscitus Posted July 26, 2018 Share Posted July 26, 2018 Enabling Mode ON: Speaking of CKE SSP bushings - tdck has now made a bunch of great inserts for most of our 5th gen and 6th gen transmissions flavors... 5EAT, CVTs, etc. soon also HT-CVTs. https://legacygt.com/forums/showthread.php/cvt-transmission-mount-insert-cke-ssp-267950.html?t=267950&highlight=cvt+insert Enabling Mode OFF. Link to comment Share on other sites More sharing options...
ssulb Posted July 27, 2018 Share Posted July 27, 2018 I just ordered an OEM 26mm front sway bar and the CKE SSP for it. I am excited to get them. But I am also debating on front sway bar links. I would like to know if there is anything better than OEM or Moog. Link to comment Share on other sites More sharing options...
Perscitus Posted July 28, 2018 Share Posted July 28, 2018 Rallitek or SuperPro for 2015+ WRX, but ideally just stick with Moogs and call it a day. In the back, SuperPro or also Moogs. Whatever you do - do not get any adjustable end-links, anything requiring shims, anything M10 (5th gen 3.6Rs use M12 bolts), none of the special designs you see from many typical names. OE/OE-like is ideal. Link to comment Share on other sites More sharing options...
Humble Rumble Posted July 28, 2018 Share Posted July 28, 2018 Rallitek or SuperPro for 2015+ WRX, but ideally just stick with Moogs and call it a day. In the back, SuperPro or also Moogs. Whatever you do - do not get any adjustable end-links, anything requiring shims, anything M10 (5th gen 3.6Rs use M12 bolts), none of the special designs you see from many typical names. OE/OE-like is ideal. I will say, the Moogs I got that were listed specific from the 10-14 Legacy did come with M12 bolts, same as the 15 STI Moogs as well. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
