need bb Posted July 15, 2018 Share Posted July 15, 2018 Anyone care to share their DW 850cc injector latency numbers? I thought my latency's numbers are spot on, but the AFR goes slightly lean upon throttle tip in. At this point some confirmation that I am close would help me sleep Link to comment Share on other sites More sharing options...
utc_pyro Posted July 15, 2018 Share Posted July 15, 2018 Why not try and adjust the tip-in with the tip-in tables instead of messing with your injector latency values? Link to comment Share on other sites More sharing options...
need bb Posted July 15, 2018 Author Share Posted July 15, 2018 I have tried and while my initial throttle tip in has stable AFRs, my AFRs go lean for about 1 seconds before recovering. I have tried to extend the amount of time tip in enrichment runs, but I am already activating it 3x the stock values and still have issues. Given this I feel my latency's might be too low. Link to comment Share on other sites More sharing options...
utc_pyro Posted July 15, 2018 Share Posted July 15, 2018 Figure out your flow and latency numbers using steady state conditions. Did you set your low pulsewidth compensation tables? If not that might screw with getting the correct latency value. So are you seeing a rich then lean blip? Measured via the factor AFR sensor or your wideband? In both closed and open loop? How close is your target boost table to reality? Also we have Tau-x tables that do fueling compensation based load changes, and it fires off a few seconds after tip-in. Most people see that as going rich though. Link to comment Share on other sites More sharing options...
need bb Posted July 16, 2018 Author Share Posted July 16, 2018 Thanks for the response. I didn't touch the low pulsewidth compensation tables as I am using the DW sidefeeds which are based on the OEM Denso's. I am seeing the issue in closed loop when in vacuum cruising around town. I have measured it via AFR sensor and my wideband. I took some logs showing me increase the throttle angle and the AFRs going lean for at least .5 seconds afterwards. Sadly my wideband wasn't working today so that is one more thing to troubleshoot.romraiderlog_20180715_225344.csv Link to comment Share on other sites More sharing options...
need bb Posted July 27, 2018 Author Share Posted July 27, 2018 Increased the injector latency by a few percent, but didn't make a difference. On tip in you can see my target fueling is much different from the actual from the wideband. Link to comment Share on other sites More sharing options...
