edgemoulic Posted July 6, 2018 Share Posted July 6, 2018 I got a new shoes on mine and I’m worried on the wear if it will be even on all of the sides. I just got the tires these year so I can’t tell anythbig yet. Is there some way or to check before I go for an alIgnment? Rears have new shocks front is still the OEM one and planning to change it. Any guide for this? Thank You in advance. Link to comment Share on other sites More sharing options...
E46erak Posted July 6, 2018 Share Posted July 6, 2018 Short of having your own equipment (toe plates, angle finder for camber, etc) your best bet is to go to an alignment shop and have them put it up on the rack. Odds are that if you have changed parts (rear shocks) that the alignment is slightly imperfect. Many shops may even do an "alignment check" for free, so you can decide whether to go ahead and do it or not. Always recommended with new tires! Link to comment Share on other sites More sharing options...
johnyaya Posted July 7, 2018 Share Posted July 7, 2018 Change front struts before alignment. The struts I changed (Outback) had ecentric bolts, so mark before removing. Link to comment Share on other sites More sharing options...
