Beamercub Posted June 20, 2018 Share Posted June 20, 2018 I have been seeing cars with brake lights that flash 3 times then steady on? And each time the pedal is pushed they repeat the flashing.... I saw a crosstreck that had this feature on the third brake light.... Is this some type of replacement bulb? Or does some type of device get spliced on put between connections? I used to have license plate lights on my motorcycle that would do the flashing then steady on.. Any insight would be awesome. Thanks. Link to comment Share on other sites More sharing options...
upstater Posted June 20, 2018 Share Posted June 20, 2018 I had modulators on my motorcycle, both for brake and headlight (which is legal on a motorcycle, but not a car). They do increase visibility to other motorists, the headlight modulator is the best because people think you either have an electrical issue or a few people actually 'pull over' for you, while in general I felt less people took risky left hand turns violating my right of way (which is a huge cause of accidents for motorcycle riders). Link to comment Share on other sites More sharing options...
