Chaztschida Posted June 5, 2018 Share Posted June 5, 2018 Been dealing with this for like 1 1/2 years now keep putting bandaids on but i cant take it anymore. Read about removing them and people say thats pretty dangerous because how hot the cat gets I read about just removing the cat all together and apparently that sounds absolutely awful but i was thinking could i just replace it with another resonator or even one of those tube shaped mufflers? That would get rid of the rattle AND remove the heat and shitty sound problem right? Couldnt find anything about this anywhere Link to comment Share on other sites More sharing options...
apexi Posted June 6, 2018 Share Posted June 6, 2018 Drill a small hole in the shield, and put a screw in the hole until it makes contact with the cat. That'll brace the heatshield and should stop the rattle. Link to comment Share on other sites More sharing options...
ronemus Posted June 6, 2018 Share Posted June 6, 2018 I've used header wrap (fiberglass fabric tape) and it worked well. Be sure to use the silicone coating spray because the tape is fragile once the sizing burns off. Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted June 11, 2018 Share Posted June 11, 2018 I've got a hose clamp around mine to keep it from making noise. Link to comment Share on other sites More sharing options...
ronemus Posted June 12, 2018 Share Posted June 12, 2018 I've got a hose clamp around mine to keep it from making noise. Hose clamps work fairly well on the headers and pipes, but not on the catalyst shields. That's why I ditched the whole mess and wrapped it all in header tape. Link to comment Share on other sites More sharing options...
iyalla Posted July 25, 2018 Share Posted July 25, 2018 Hose clamp has been working really well on my Accord Link to comment Share on other sites More sharing options...
98legwag Posted July 27, 2018 Share Posted July 27, 2018 Hose clamp around the cat shields on my 3.0R has worked great. I just check it at every oil change to see if it needs to be tightened. Link to comment Share on other sites More sharing options...
Chaztschida Posted July 29, 2018 Author Share Posted July 29, 2018 Just now got notified i had comments here... wth So ive tried the screw in it and it eventually either vibrates out or maybe winter/salt messes it up idk but it never lasts. Clamps also vibrate loose amd stop working. Ive thought about header wrap but ive read that will cause the cat to get alot hotter inside and eventually burn out also idk what the cats are made of but ive been told never to wrap anything unless its SS or ceramic coated because of rust? I got a guy that can weld im thinking about just chopping it out all together since ill have the one on the manifold still. I just dont know if it would cause any issue Link to comment Share on other sites More sharing options...
cluesblues Posted July 29, 2018 Share Posted July 29, 2018 I had the whole thing welded together and then a hole cut in the middle to keep rocks from collecting in there, which seemed to be my problem Link to comment Share on other sites More sharing options...
afrascione Posted August 7, 2018 Share Posted August 7, 2018 just had my heat shields remove by my local muffler shop $100.00 Link to comment Share on other sites More sharing options...
aperson Posted August 20, 2018 Share Posted August 20, 2018 I use some stainless steel wire and some tie wire pliers (they have a handle you pull on them and it'll twist the ends together for you) to keep multiple cars heatshields from rattling. https://goo.gl/images/YmunAE Link to comment Share on other sites More sharing options...
