Rodger Posted May 31, 2018 Share Posted May 31, 2018 Found a good deal on some 18" wheels and tires (245/40R18) for $450.00. Problem is I have an 05 Legacy GT Limited that’s 4x100 and these are 4x114 from a 2014 WRX. Does anyone know if I use wheel adapters (1in or less) will those tires and rims tuck or will I need to do fender modifications. Car is stock height. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Brady Posted May 31, 2018 Share Posted May 31, 2018 I've never heard of anyone doing this. Sounds like a poor choice. Link to comment Share on other sites More sharing options...
fedaykin Posted June 1, 2018 Share Posted June 1, 2018 Get wheels that fit. You're looking at minimum 25mm for the spacers. Link to comment Share on other sites More sharing options...
jrho Posted June 1, 2018 Share Posted June 1, 2018 Found a good deal on some 18" wheels and tires (245/40R18) for $450.00. Problem is I have an 05 Legacy GT Limited that’s 4x100 and these are 4x114 from a 2014 WRX. Does anyone know if I use wheel adapters (1in or less) will those tires and rims tuck or will I need to do fender modifications. Car is stock height. Sent from my iPhone using Tapatalk To let you know the Legacy GT is actually a 5x100 not a 4x100. Also the 2014 WRX is a 5x100 as well so those wheels should work but without width or offest, it'll be tough to tell if you will need to do fender modifications. If the wheels are from a 2014 WRX STI, then they will be 5x114 and will require adapters. Project Kics sells some high quality adapters for 5x100 to 5x114. They make them as slim as 11mm but will require you to trim the original lug studs Link to comment Share on other sites More sharing options...
