CaptChuck Posted May 16, 2018 Share Posted May 16, 2018 We have a 1996 Legacy Brighton 2.2. The driver’s door is dinged badly enough we want to replace it. My door does not have power windows nor locks. All I can find in the wrecking yards are powered window type doors. Anyone know if the basic door is the same so all I would need to do is swap out the powered parts (window and locks) and interior trim and then replace them with the ones from my door? Link to comment Share on other sites More sharing options...
Das Ninjabot Posted May 16, 2018 Share Posted May 16, 2018 You'll be just fine going that route. I believe the only difference in doors is the rear glass when going between a sedan and a wagon. Other than that you should be good to go. Link to comment Share on other sites More sharing options...
Brighton96 Posted May 17, 2018 Share Posted May 17, 2018 The doors are physically the same, so just get the nicest one you can in the same color paint and then just remove all the wiring and extra stuff from the new door. Reuse the brighton door card and you'll have to swap the window regulator, but it's definitely do-able. Link to comment Share on other sites More sharing options...
CaptChuck Posted May 17, 2018 Author Share Posted May 17, 2018 Thanks guys, I had hopes I was going to get answers that I got. Link to comment Share on other sites More sharing options...
