bmart Posted May 14, 2018 Share Posted May 14, 2018 Hey all. I have a lot of track miles on two wheels and will be taking a two day class in my 2000 GT in the fall. I'm curious what kind of guidance you would be willing to provide with regard to (cold) track tire pressures. I will be running BF Goodrich street tires in stock sizes, either the g-force Super Sport H-rated on the GT now or G-force Comp-2 A/S on the wagon now. I run 34-35 on the street all of the way around. Thanks a bunch. Link to comment Share on other sites More sharing options...
Th3Franz Posted May 20, 2018 Share Posted May 20, 2018 Often I had to run higher tire pressure to keep them from rolling over too much. I'd start at 37-38 PSI and see how they wear. As they heat up, you can probably drop the pressure some. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
boxkita Posted December 8, 2018 Share Posted December 8, 2018 So...how did your car work out? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
derp Posted December 9, 2018 Share Posted December 9, 2018 Often I had to run higher tire pressure to keep them from rolling over too much. I'd start at 37-38 PSI and see how they wear. As they heat up, you can probably drop the pressure some. I had the same experience, and ran around the same pressures. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
