BP5 Posted May 14, 2018 Share Posted May 14, 2018 I've done my 6mt swap a while ago. I've finally picked up a mapdccd controller to complete the swap. I plan to run all the wires and have it be able to run on auto mode. I would like to ask the experts here some wiring related questions. Where are you guys using for tps signal? Is it better to tap the pedal position or the throttle body position? Where is the best place to tap the speed signal? At the cluster, abs module, or ecu? Where are you guys mounting the controller? optimal wire routing? Link to comment Share on other sites More sharing options...
Waxiboy Posted May 15, 2018 Share Posted May 15, 2018 I have an 09 STi 6MT. TPS tapped by the ECU...it was a pain to do because there are so many wires bunched up there. The controller is double taped behind the ashtray, under the HVAC control. Mine did not need the speed sensor. Link to comment Share on other sites More sharing options...
