Stevo F Posted May 14, 2018 Share Posted May 14, 2018 We got home tonight after driving the GT sedan up to visit my parents. When we arrived home, I shut it off, but the brake lights were still shining bright, with no foot on the brake (no change when you do depress the brake pedal). I also noticed that the third brake light is out (not sure if the bulbs burned out previously or if that's another issue). I did the obvious check of the switch on the steering column to no avail (it's brake lights vs. taillights anyway). I pulled the battery cable until I can dig into it tomorrow. The obvious thing to me would be the brake light switch is shorting out- has anyone else encountered this and had any other causes of it? Link to comment Share on other sites More sharing options...
doublechaz Posted May 14, 2018 Share Posted May 14, 2018 No info, but I agree the switch is the first place to look. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 14, 2018 Share Posted May 14, 2018 I 3rd the brake light switch. I don't recall the design, but if its threaded, make sure you adjust it like the old one so it works properly. Link to comment Share on other sites More sharing options...
Stevo F Posted May 15, 2018 Author Share Posted May 15, 2018 I checked it out in the light of day this morning. I found the plastic grommet that snaps into a hole in the bracket pedal arm and contacts the brake light switch had disintegrated into a few small pieces found on the driver's side floor mat ([probably while driving home last night) and now the switch wasn't being pushed in, since it was contacting the hole,, so the circuit remained closed. I found a plastic screw that fit into the hole and all is working correctly again. Link to comment Share on other sites More sharing options...
