Strangeskull Posted May 11, 2018 Share Posted May 11, 2018 I have a 05 LGT wagon I’m building the motor in and I have a question.......I have seen moroso and killer B refer to their OEM pan pickups not working in certain non STI oil pans How can I tell if it will work with mine or not? The reference is usually to LGT and FXT cars But what difference am I looking for??? Thanks in advance Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jrho Posted May 11, 2018 Share Posted May 11, 2018 I have a 05 LGT wagon I’m building the motor in and I have a question.......I have seen moroso and killer B refer to their OEM pan pickups not working in certain non STI oil pans How can I tell if it will work with mine or not? The reference is usually to LGT and FXT cars But what difference am I looking for??? Thanks in advance Sent from my iPhone using Tapatalk I believe the early year Legacy GTs had a slightly difference oil pan compared to the 2006+ or 2007+ (I can't remember which one) which shared the same oil pan as the STI. Given that you have a 2005, you'll probably need to get a newer style oil pan for the pickup to work Link to comment Share on other sites More sharing options...
Strangeskull Posted May 11, 2018 Author Share Posted May 11, 2018 Thank you for the reply I have access to second hand oil pans but what your saying is the difference is not really noticeable so for instance I could not “pick one out of a line up” really Does anybody out there have pictures of the difference?? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted May 11, 2018 Share Posted May 11, 2018 Go to most any dealers web site and look up the part numbers for the oil pans from the Parts link Or go to one of the sticky's for the Vendors on here, like Heuberger 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
