06SubLegTx Posted May 10, 2018 Share Posted May 10, 2018 Hello, So when I start my car and let it run for a few minutes and then shut it off. I hear a weird noise from under the dash (behind the radio/A/C Controls). It's kind of like a motor/relay or something shutting down. I have also noticed it does it with or without starting the engine. Engine Cold or at Operating Temp Attached is a sound recording of it. If someone can tell me how to attach it. I don't see a way. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 10, 2018 Share Posted May 10, 2018 Most likely your mode actuator for hvac system. Very common problem and fairly easy to fix. Search for it on the forum and you should find a plethora or videos and pics. Link to comment Share on other sites More sharing options...
06SubLegTx Posted May 10, 2018 Author Share Posted May 10, 2018 I changed the big one Air Mix Motor # 72131AG26A on the pass side, still does it. See link: https://www.google.com/search?biw=1422&bih=666&tbm=isch&sa=1&ei=OsfzWtuaAqTijwTXkYfQCg&q=subaru+72131AG26A&oq=subaru+72131AG26A&gs_l=img.12...0.0.0.62225.0.0.0.0.0.0.0.0..0.0....0...1c..64.img..0.0.0....0.VQowMM24mMI#imgrc=fRzI_Jemn4i8zM: Link to comment Share on other sites More sharing options...
