Hbaum1 Posted April 30, 2018 Share Posted April 30, 2018 1997 legacy wagon ej22. 260,000 miles. Installed new timing belt. Got it right on second Try? Installed new plugs, water pump, belt tensioner and semi used coil. Car started and idled good. Revved her up a few times. Sounded great. Son drove her down the road and back. Responded good. Power was good. Parked her and she was running rough. Got progressively worse until she was kind of 'loping' at idle. Car shows no codes. At this point we are lost and I don't want my son to just throw parts at it hoping for a fix. Any help will be appreciated. Thank you in advance. Link to comment Share on other sites More sharing options...
eagleeye Posted April 30, 2018 Share Posted April 30, 2018 congrats on a running great ej221 what kit brand did you get? (choice would be OEM parts or a Aisin kit = made in japan,...not chinese junk in a good named box). seems like you jumped a tooth, and should open it up and spin the belt by hand checking. Link to comment Share on other sites More sharing options...
Hbaum1 Posted May 1, 2018 Author Share Posted May 1, 2018 Thank you for your response Eagleeye. Everyone keeps saying it jumped but, it is hard to believe it could do that with that much tension. I told my son to check that first before spending any money on her. I don't know the kit he bought. Wasn't cheap. Don't think it was Chinese. I tell him to steer clear of that stuff. Have a great day Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2018 Share Posted May 2, 2018 Check the timing marks to see if things still line up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hbaum1 Posted May 3, 2018 Author Share Posted May 3, 2018 Thank you, can I have your Car? Link to comment Share on other sites More sharing options...
easy fix Posted May 4, 2018 Share Posted May 4, 2018 Double check timing first. Also did you put NGK spark plugs in? If those things are good, Maybe try your old coil again just for kicks and see if that fixes the problem. (You didn't say what was wrong with it). Good luck! Link to comment Share on other sites More sharing options...
Hbaum1 Posted May 5, 2018 Author Share Posted May 5, 2018 Going to do the timing check today. Old coil is definitely dead. NGK plugs, yes. Sounds like she is off one tooth. Does not shake violently like she did the first jumped belt. Link to comment Share on other sites More sharing options...
rhd gvr4 Posted November 3, 2018 Share Posted November 3, 2018 Not too much work to pull the covers,good luck Link to comment Share on other sites More sharing options...
