smith222 Posted April 17, 2018 Share Posted April 17, 2018 So I'm planning on going with the Tomioka twin scroll set up on my 07 Spec B and had some question when it come to external wastegates. Im currently running their TD05-18g and the only issue I'm having with it is over boost in cold weather. Im hoping the twin scroll wont have the same issue but I want to be prepared. So I know that on a normal up pipe installing a external wastegate is repetitively straight forward but the up pipe that comes with the kit has two pipes as opposed to one. Would I need to run two external wastegates one on each pipe or just one and if so on which pipe? Link to Turbo: https://www.tomiokaracing.com/products/subaru-legacy-gt-td06-20g-twin-scroll-turbo Link to Kit: https://www.rallitek.com/turbos/2833-tomioka-td06-20g-twin-scroll-turbo-kit-wrx-2008-2014-legacy-gt-2005-2009.html Link to comment Share on other sites More sharing options...
birdmayne Posted April 17, 2018 Share Posted April 17, 2018 Yes, two wastegates. John Hancock Link to comment Share on other sites More sharing options...
Th3Franz Posted April 17, 2018 Share Posted April 17, 2018 You should adjust your tune for cold weather if it is over boosting. Usually I increase the wgdc temperature compensation table -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
smith222 Posted April 17, 2018 Author Share Posted April 17, 2018 Planned on it. The issue didnt present its self till I went home on leave and we had a cold snap. We're going to rework the tune once I get back but both me and my tuner have a nasty sneaking suspicious that because my exhaust is completely catless a external will be required. Given that from the looks of it the internal wastegates on the twin scroll they are double the size it hopefully wont be an issue on the new set up Link to comment Share on other sites More sharing options...
