azm613 Posted April 14, 2018 Share Posted April 14, 2018 I have recently been looking into lowering my outback. It is a BL9 sedan that currently rides too high to be visually appealing to me. I have been looking at tein street basis z coilovers as a means to lower it a few inches. I want to make sure that the Teins for the Legacy GT will fit my Outback. I also want to know if these are a good enough quality and will be reliable for a few years. I do not track my car, it is only my daily. Link to comment Share on other sites More sharing options...
jkaic Posted April 15, 2018 Share Posted April 15, 2018 Can you source a set of used LGT struts and rear bumpstops? Should do the trick. http://legacygt.com/forums/showthread.php/lgt-wagon-suspension-swapped-into-outback-xt-140548.html Link to comment Share on other sites More sharing options...
azm613 Posted April 17, 2018 Author Share Posted April 17, 2018 Can you source a set of used LGT struts and rear bumpstops? Should do the trick. http://legacygt.com/forums/showthread.php/lgt-wagon-suspension-swapped-into-outback-xt-140548.html Looking at coilovers so I have the adjustability. I want to have it low in the summer and stock height in the winter (stock LGT height). Link to comment Share on other sites More sharing options...
derp Posted April 17, 2018 Share Posted April 17, 2018 DO you live where it snows? If so, you probably don't want coilovers on a daily. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
rougeben83 Posted April 18, 2018 Share Posted April 18, 2018 Looking at coilovers so I have the adjustability. I want to have it low in the summer and stock height in the winter (stock LGT height). That's what most people shopping for coilover *think* they will do, but I can tell you pretty much once you set a ride height, you're either going to be too lazy or stuck with whatever you set it to after 1 winter. Link to comment Share on other sites More sharing options...
jkaic Posted April 20, 2018 Share Posted April 20, 2018 That and having to play around with alignment every season.. I've been swapping my struts twice a year but could not get alignment to spec when i'm low in the summer Link to comment Share on other sites More sharing options...
