az645 Posted April 11, 2018 Share Posted April 11, 2018 I just received my new 2018 3.6R and was wondering what bulbs to use to upgrade the interior and under door lights. I just upgraded from a 2011 3.6 R and the bulbs that I upgraded on that vehicle car are discontinued from SuperbrightLED's.com. Also any tips on removing the covers, especially for the map lights? Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 11, 2018 Share Posted April 11, 2018 I upgraded both door lights and visor lights since the map lights were already led. Map lights should be simple, you just need to press on the dark spots with a flat head screwdriver and they should pop out. I had a friend do the door lights, he said it was simple. Here is a video: Link to comment Share on other sites More sharing options...
gathermewool Posted April 11, 2018 Share Posted April 11, 2018 Have you checked on diodedynamics? '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 12, 2018 Share Posted April 12, 2018 if they are not already LED Map lights Done light Door courtesy lights trunk light (use a LED strip) Link to comment Share on other sites More sharing options...
gathermewool Posted April 12, 2018 Share Posted April 12, 2018 trunk light (use a LED strip) For a Forester, I would agree. For our Legacy, it depends. Unlike the Forester, which has its light low, making it nearly useless, even with a much brighter LED, the Legacy light it top and center in the trunk, so light is dispersed much better. The light strip is definitely an improvement over a single bright LED, that’s for sure, but I find the single bright LED to be good enough for me. I replaced the incandescent trunk light with the brightest replacement LED diodedynamics had available and the lighting is much improved over the relatively dim OEM bulb. '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
mkosior81 Posted April 12, 2018 Share Posted April 12, 2018 I stuck with most of the LEDS from companies on Amazon and they do the job. For headlights and turn signals I went with Diode Dynamics only because I didn’t want to have to install load resisters. All of the interior lights and door jams are just a cover that can be pryed off with a small flathead or if you have a plastic pry. I slid it in 1/4 way to the center and they just pop off. Link to comment Share on other sites More sharing options...
upstater Posted April 12, 2018 Share Posted April 12, 2018 my door puddle lights were replaced with eBay ones that project a Subaru logo on the ground when I open the door. Link to comment Share on other sites More sharing options...
citadel Posted April 13, 2018 Share Posted April 13, 2018 Make sure you buy the ones that have a heavy aluminum backing plate to dispense the heat.The second pair have worked out great! Link to comment Share on other sites More sharing options...
Prmdc1 Posted April 13, 2018 Share Posted April 13, 2018 Make sure that they are anti-flicker. My first pair flickered like crazy. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 13, 2018 Share Posted April 13, 2018 For a Forester, I would agree. For our Legacy, it depends. Unlike the Forester, which has its light low, making it nearly useless, even with a much brighter LED, the Legacy light it top and center in the trunk, so light is dispersed much better. The light strip is definitely an improvement over a single bright LED, that’s for sure, but I find the single bright LED to be good enough for me. I replaced the incandescent trunk light with the brightest replacement LED diodedynamics had available and the lighting is much improved over the relatively dim OEM bulb. The LED strip can be positioned deeper into the trunk for even better lighting.. I mounted mine to the rear deck and the lighting is better. Link to comment Share on other sites More sharing options...
Rayho Posted May 14, 2018 Share Posted May 14, 2018 Wonder whats the model of the door courtesy light? Also, how to run the power for the LED strip for the trunk? get the power from that stock little tiny light? Link to comment Share on other sites More sharing options...
ammcinnis Posted May 14, 2018 Share Posted May 14, 2018 Wonder ... how to run the power for the LED strip for the trunk? get the power from that stock little tiny light? Yes. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
IdkWhatUserNameToUse Posted May 23, 2018 Share Posted May 23, 2018 If I wanted my door courtesy light to match the side mirrors projection lights, what color would that be? My courtesy lights are at 6500k LEDs right now and are a lot whiter than those mirror puddle lights. Any guesses? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Rayho Posted May 25, 2018 Share Posted May 25, 2018 If I wanted my door courtesy light to match the side mirrors projection lights, what color would that be? My courtesy lights are at 6500k LEDs right now and are a lot whiter than those mirror puddle lights. Any guesses? Sent from my iPhone using Tapatalk I guess below 6500k would be ok. 8000k will turn into bluish. Link to comment Share on other sites More sharing options...
