djsethmac.com Posted November 2, 2005 Share Posted November 2, 2005 Hi, I've read the posts forever and I still have a couple of questions. Has anyone wired their system using pre-amp level outs WITHOUT using LOC's or CleanSweep? Does it exist? I just bought my 2005 Legacy 2.5 GT Limited, my first new car. Got an amazing price and really like the car! I pulled the sound system out of my Audi A4. I have 2 MB Quart seperates, 5-1/4 inch woof with seperate tweet, perfect for what is in there now with external crossover boxes, a set of PPI 2-way 6.5" round coaxials, an Alpine 5 channel amp, 100 watts per channel and a sub out and a subwoofer. I'd like to put all that in the Soooobie using the existing HU. I have never really liked LOC, so any advise y'all? Link to comment Share on other sites More sharing options...
PGT Posted November 2, 2005 Share Posted November 2, 2005 First, the car takes 6.5's all the way around. Second, the stock head unit can't be swapped out so you need to convert speaker level to line out. Your Alpine might have it built in. If not, you need a way to step the voltage down and an LOC or CleanSweep is the answer. The CS adds an EQ function to get rid of the factory EQ curve. Link to comment Share on other sites More sharing options...
djsethmac.com Posted November 2, 2005 Author Share Posted November 2, 2005 Thanks man! I know the HU can't be swapped. I was not sure if the Crutchfield speaker spacers will accept my 5-1/4's ('cause it sounds like I'll need to use the spacers). I wasn't sure if anyone has found a way around the LOC, but the Alpine amp having the LOC built in is a VERY good point! Thanks! Link to comment Share on other sites More sharing options...
PGT Posted November 2, 2005 Share Posted November 2, 2005 you will need a customer spacer.....6.5 on the outside with a cut-out for 5.25. Where are you located??? I can make you a set cheap Link to comment Share on other sites More sharing options...
djsethmac.com Posted November 2, 2005 Author Share Posted November 2, 2005 Connecticut. What audio set up do you have personally? Link to comment Share on other sites More sharing options...
PGT Posted November 2, 2005 Share Posted November 2, 2005 stock right now, but I have a CS, Quarts, JL and Quart amps in the garage waiting forr time to install. Link to comment Share on other sites More sharing options...
djsethmac.com Posted November 2, 2005 Author Share Posted November 2, 2005 I just not sure I like the idea of using/needing a seperate volume with the CS. Link to comment Share on other sites More sharing options...
PGT Posted November 2, 2005 Share Posted November 2, 2005 yeah....I still haven't figured out where I will install it. I have an RBC for the JL amp too.... Link to comment Share on other sites More sharing options...
djsethmac.com Posted November 2, 2005 Author Share Posted November 2, 2005 Rbc? Link to comment Share on other sites More sharing options...
PGT Posted November 2, 2005 Share Posted November 2, 2005 remote bass controller. A level knob for the sub. Another volume control. Uggh. Need them both, but where to install?? Link to comment Share on other sites More sharing options...
djsethmac.com Posted November 2, 2005 Author Share Posted November 2, 2005 I may be wrong, I read only quickly, but I think with the CS, you don't use the volume on the radio, you use it on a supplied new knob from CS. Is that worng? Link to comment Share on other sites More sharing options...
